[INSTALLATION GUIDE] --viper for android -- [ONEPLUS 3/3T][PIE]
  1. Ranjithsmart
    Jelly Bean Jul 1, 2019
    Ranjithsmart , Jul 1, 2019 :
    VIPER FOR ANDROID IS THE BEST EQUALIZER SO FAR ON ANDROID PLATFORM,
    I GUARENTEE YOU FOR THE BEST AUDIO EFFECTS.
    I TRIED THIS METHOD ON MY ONEPLUS 3T AND IT WORKS PERFECTLY,YOU COULD ALSO TRY IT ON ONEPLUS 5/5T,6/6T,7 SERIES (RUNNING PIE).
    TRY THIS AT YOUR OWN RISK I AM NOT RESPONSIBLE FOR ANY BRICK.
    PRE-REQUIREMENTS:
    => BOOTLOADER UNLOCKED
    => OOS 9.x.x [PIE]
    => TWRP RECOVERY
    => MAGISK [RECOMMENDED]
    LINK TO INSTALL MAGISK:
    https://forum.xda-developers.com/apps/magisk/official-magisk-v7-universal-systemless-t3473445
    LET'S START THE PROCEDURE:
    * Download the latest viper for android (given below).
    * Disable other equalizers like audio tuner in settings.
    * Install latest busybox from playstore , I personally prefer busybox pro.
    * Install the drivers using busy box
    * Install any root explorer and
    Navigate to /vendor/etc.Look for a file named audio_config.conf and rename it to audio_effects.conf_bkp.
    {IF YOU FAILED TO DO THIS THE DRIVERS ON VIPER FOR ANDROID WILL NOT GET INSTALLED}
    * Using magisk manager install viper for android apk/zip.
    (once it installed you can see viper for android in modules section)
    * Now get into viper and install the drivers.
    (It takes some time to reboot)
    * Once it gets rebooted BOOOM, it will work.
    CHECKING:
    CLICK DRIVER STATUS ICON
    IT WILL SHOW
    Status:
    Normal
    Audio format: supported
    IN CERTAIN CASES IF IT IS NOT WORKING:[
    SOLUTIONS]
    ==> Get into settings > battery > battery optimization > viper for android > select Don't optimize.
    (most of the time it works)
    ==>OR else install SElinux mode changer apk and change the mode to permissive.
    DOWNLOAD LINKS:
    OFFICIAL VIPER FOR ANDROID LATEST VERSION:
    https://labs.xda-developers.com/store/app/com.pittvandewitt.viperfx
    FOR INTERESTING VIPER PROFILES FOLLOW:
    FOR C AUDAY'S PROFILE:
    https://forums.oneplus.com/threads/v4a-for-android-marshmallow-discussion-group.410033/
    XDA FORUM:
    https://forum.xda-developers.com/showthread.php?t=2324454
  2. Ranjithsmart
    Jelly Bean Jul 2, 2019
  3. buck_shots_
    Cupcake Jul 3, 2019
    buck_shots_ , Jul 3, 2019 :
    No. Haven't tried it yet. Still waiting for someone else to say if it's worth trying or not
  4. Ranjithsmart
    Jelly Bean Jul 3, 2019
    Ranjithsmart , Jul 3, 2019 :
    Let's see! [e]1f601[/e]
  5. nahid.onim
    Cupcake Feb 15, 2020
