290
[INSTALLATION INSTRUCTIONS][FAQs] OxygenOS 3.0.1
  1. Notch_1608
    Honeycomb Jun 4, 2016
    Notch_1608 , Jun 4, 2016 :
    Ouu. Being a mod has its benefits, eh? xD
  2. EmmanuelMalho
    Donut Jun 4, 2016
    EmmanuelMalho , Jun 4, 2016 :
    Hi all!
    I'm having a little trouble in this update as I can't get the Oxygen Recovery to find the update file.
    I'm currently using the Beta version of OOS, released some time ago.
    I downloaded the .zip on the downloads' page and load that to my OP2's internal storage (first level storage folder - can't recall the name) (where I previously put the beta version for the prior update, I've already removed it), but when I launch recovery and Install from local, the phone vibrates and nothing happens.«.
    Any advice please?
    Thanks in advance!
  3. locxFIN
    KitKat Jun 4, 2016
    locxFIN , Jun 4, 2016 :
    Is your phone encrypted?
    EmmanuelMalho likes this.
  4. EmmanuelMalho
    Donut Jun 5, 2016
    EmmanuelMalho , Jun 5, 2016 :
    locxFIN, thank you!
    It was encrypted, I removed the encryption and the file shows up. I'm updating as I'm writing!
    locxFIN likes this.
  5. beingathar
    Froyo Jun 5, 2016
    beingathar , Jun 5, 2016 :
    Hello @Naman Bhalla,
    I am currently on OOS Beta 2 with orange TWRP. Please tell me how to Flash official CM13 as OP2 is my primary & only phone.
  6. locxFIN
    KitKat Jun 5, 2016
    locxFIN , Jun 5, 2016 :
    A simple clean flash will suffice. Same superSU and Xposed if you use those. Dont forget www.opengapps.org ARM64, Android 6.0 and any of the packages (though I recommend nano)
  7. beingathar
    Froyo Jun 5, 2016
    Hello @IocxFIN. Thank you!
    So I can right away flash official CM13 zip + Gapps + Supersu from the Orange TWRP recovery directly?
  8. locxFIN
    KitKat Jun 5, 2016
    Yes you can. But wipe cache+system+data first to be on the safe side.
  9. Naman Bhalla
    Recognized developer Recognized Developer Jun 5, 2016
    Naman Bhalla , Jun 5, 2016 :
    Actually wiping all these 4 is a must and not just to be on a safe side. ;)
    locxFIN likes this.
  10. locxFIN
    KitKat Jun 5, 2016
    Well, in this case unsafe side means bricking your phone :D
    Naman Bhalla likes this.
  11. Cichy26
    Cupcake Jun 6, 2016
    Cichy26 , Jun 6, 2016 :
    I Can't find solution of lost battery icon on lockscreen when i update to 3.0.2. Can anybody help with it?
  12. pilot_ctg
    Cupcake Jun 6, 2016
    pilot_ctg , Jun 6, 2016 :
    i trying your gide but i saw my bootloader is locked. i try to unlock but showing bootloader fail. now i m stuck with oneplus logo cant recovery.pls help
  13. Naman Bhalla
    Recognized developer Recognized Developer Jun 6, 2016
    Naman Bhalla , Jun 6, 2016 :
    Use Method 1 from mega unbrick guide for a hard bricked oneplus 2 and then adb sideload oos 3.0.2 full zip and then enable developer options and oem unlocking and unlock the phone.
  14. bigred065
    Froyo Jun 6, 2016
    bigred065 , Jun 6, 2016 :
    Hey @Naman Bhalla
    I'm on TWRP modified (orange) and rooted, had 3.0.1. Followed instruction to update, flashed full rom OnePlus2Oxygen_14_OTA_019_all_1606041303.zip followed by the patch (OnePlus2Oxygen_14_OTA_018-019_patch_1606041303) and then SU. During the patch install i got an error saying UNKNOWN COMMAND [wipe_data] but after the install,cache and dalvik wipe i booted, it did the app upgrading and worked pretty fine (i got bugs here and there)
    should i be concerned?
  15. jsb007
    Gingerbread Jun 6, 2016
  16. Spannaa
    KitKat Jun 6, 2016
    Spannaa , Jun 6, 2016 :
    No, the error is normal.
    Why did you flash the 3.0.1 > 3.0.2 OTA zip after the full 3.0.2 zip though?
  17. bigred065
    Froyo Jun 6, 2016
    When i read the instructions i thought that's what i had to do. I thought it was weird but then again i'm nowhere as good as you guys about flashing so i tried to follow the instruction as best as i thought.
  18. smrdelj
    Gingerbread Jun 7, 2016
  19. vranand
    Cupcake Jun 7, 2016
    vranand , Jun 7, 2016 :
    Can we enable MultiWindow in an non-rooted device running MM? How to do it?
  20. abyknikhil
    Cupcake Jun 7, 2016
