16
Installation Instructions for H2OS v1.4 Marshmallow
  1. Saeed Ashif Ahmed
    Ice Cream Sandwich Apr 8, 2016
    Saeed Ashif Ahmed , Apr 8, 2016 :
    Yesterday, Chinese OnePlus 2 got Official Hydrogen OS v1.4 MM which is better than OOS in many expects. If you want to install h2os then follow this Guide.
    Pros :
    • Great Battery Life
    • Fingerprint sensor is faster that OOS 3.0 (I have tested simultaneously with two OnePlus 2 device)
    • New File Manager with decent features
    • Dark Mode
    • Read Mode
    • Better OTG Management
    • Flip to Mute
    • Unintentional Touch Rejection
    Cons:
    • Stock H2OS is filled with chinese bloatware (Can be remove via Titanium Backup)
    NOTE : Official TWRP and Official SuperSU doesn't work here. But Official GApps works :)
    STEPS :
    • Download Official GApps from Here : www.opengapps.org (Select Android 6.0 + Arm 64)
    • [Select Package of your choice]
    Credit : @Naman Bhalla
    • Keep all these files anywhere in the Internal Storage.
    • Boot into TWRP.
    Still Locked Bootloader with Stock Recovery ? Follow this!
    OR
    OFFICIAL OnePlus Guide :
    Wipe > Advcanced Wipe > Select Dalvik, System, Data, Cache > Swipe to wipe.
    • Go to TWRP Home.
    • Select Install.
    • Select H2os Zip.
    • Swipe to Install.
    • Go to TWRP home.
    • Select Install.
    • Select Images button at bottom right.
    • Select recovery.img
    • Select Recovery.
    • Swipe to flash.
    • Go to TWRP Home. Reboot > Recovery.
    • Wait to reboot into recovery.
    Wipe > Advanced Wipe > Select Dalvik, System, Data, Cache > Swipe to wipe.
    • Go to TWRP Home.
    • Install > Select Hydrogen OS Zip. Swipe to flash.
    • Now Go to TWRP home > Install > GApps.zip Swipe to flash
    Again Wipe Cache and Dalvik Cache
    [OPTIONAL] : Flash this supersu to root : https://www.androidfilehost.com/?fid=24459283995297946 CREDIT : @Naman Bhalla
    Again wipe DalvikCache and Cache.
    Reboot into System.
    NOTE : For the first time, System will take very Long time to start. After that, it will be fine.
    Now you are Done ! Enjoy the test of Chinese OnePlus flavor :)
    Screen Shots :
    Screenshot_20160409-012852.png Screenshot_20160409-012806.png Screenshot_20160409-013421.png Screenshot_20160409-013726.png Screenshot_20160409-091150.png Screenshot_20160409-013733.png Screenshot_20160409-110309.png
    [VIDEO] Look and Feel : Overview of H2OS MM v1.4
    cedalone, abhishek7, Spannaa and 13 others like this.
  2. Saeed Ashif Ahmed
    Jorge48197, deviantartjr and pgidia like this.
  3. SimonFullerImagery
    Jelly Bean Apr 8, 2016
    SimonFullerImagery , Apr 8, 2016 :
    Thank you. I already have the correct twrp ready because I have the os3 beta already installed. So I guess a clean flash of hydrogen instantly followed by gapps and modified su should do the trick?
    Hehe I've had that twrp error for 6 months already.
    Saeed Ashif Ahmed likes this.
  4. locxFIN
    KitKat Apr 8, 2016
    locxFIN , Apr 8, 2016 :
    That would work. Beware that stock H2OS is filled with chinese bloatware, and you can get rid of them with debloater that you find here: https://www.androidfilehost.com/?fid=24459283995315136
  5. pgidia
    Lollipop Apr 8, 2016
  6. Saeed Ashif Ahmed
    Yes the Clean Flash will working like a charm :)
  7. Saeed Ashif Ahmed
  8. Saeed Ashif Ahmed
    locxFIN likes this.
  9. locxFIN
    KitKat Apr 8, 2016
    Thanks, updated the link.
  10. SimonFullerImagery
    any real world experiences yet? I'm holding off at the moment because I don't have any real issues with oosb3 apart from crappy audio.
    gopinathr and NaterTots like this.
  11. Saeed Ashif Ahmed
    Battery.
    30 % more battery file than OOS 3.0 no doubt $
  12. Saeed Ashif Ahmed
    Ice Cream Sandwich Apr 9, 2016
  13. dpalejwala
    Honeycomb Apr 9, 2016
    gopinathr likes this.
  14. azlathi
    Froyo Apr 9, 2016
  15. xenon005
    Gingerbread Apr 9, 2016
    xenon005 , Apr 9, 2016 :
    You will if you don't flash the debloater and super su
  16. xenon005
    @Saeed Ashif Ahmed Do you have Greenify installed? I have greenify but it doesn't do automatic hibernation because on the accessibility setting it automatically disables the service. I had this bug on Kingmercian version too.
  17. Saeed Ashif Ahmed
    Saeed Ashif Ahmed , Apr 9, 2016 :
    Of Course if you need Great Battery Life and Blazing Fast FPS :)
  18. Saeed Ashif Ahmed
  19. Saeed Ashif Ahmed
    Yes. This if the First App that I used to install whenever I flash a new ROM.
    Everything in Greenify with Xposed is working fine in this ROM :) Not a single Problem :)
  20. sam9908
    sam9908 , Apr 9, 2016 :
    I am facing two issue on latest H2OS.
    1 LED notification not work
    2 Not getting message tone on receiving new message .
    Any solution for issues ?
