16
Installation Instructions for H2OS v1.4 Marshmallow
  1. Saeed Ashif Ahmed
    Ice Cream Sandwich Apr 9, 2016
    Saeed Ashif Ahmed , Apr 9, 2016 :
    Aah..ha. Don't know:)
    I'm from India :)
    #61
  2. preetfzr
    Eclair Apr 9, 2016
    preetfzr , Apr 9, 2016 :
    I am on OOS 3.0.
    Is it possible to flash this rom just wiping cache and delvik? I dont really want to remove everything from my phone.
    Thanks in advance.
    #62
  3. chitralverma
    Froyo Apr 9, 2016
    chitralverma , Apr 9, 2016 :
    This thread is about VOLTE? Anyways, So here s a question no one asked.
    For those who have used this ROM, will you recommend it over grarak's CM13 ?
    #63
  4. Saeed Ashif Ahmed
    Is your phone rooted ? Use titanium backup if you don't want to remove everything from your phone.
    Only wipe cache and delvik is not good for this flashing if you are in OOS
    #64
  5. Saeed Ashif Ahmed
    Aah ha..can't say :D
    Btw Grarak cm 13 have crappy camera app which annoyed me. Also some minor bugs are their.
    But this h2os is bugfree and faster FPS than CM 13 by Grarak.
    Apps open very fast in H2OS
    #65
  6. xenon005
    Gingerbread Apr 9, 2016
    xenon005 , Apr 9, 2016 :
    Do you have any white list app on Battery Optimization? Also do you have automatic hibernation enabled?
    #66
  7. Saeed Ashif Ahmed
    Google play Service is in the white list. and yes i have auto hibernation enabled
    #67
  8. xenon005
    Screenshot_20160409-130518.png Screenshot_20160409-130547.png Screenshot_20160409-130707.png Screenshot_20160409-131043.png
    #68
  9. Impulse37
    Impulse37 , Apr 9, 2016 :
    Hi,
    Can someone please tell me if this ROM can be flashed using the stock recovery of OOS3.0 community release (beta) ? Since this is the official rom non chinese OP2 MM recovery should be able to flash it correctly right?
    I currently have stock OOS3.0 with locked bootloader. I don't want to unlock it unless it's necessary..
    #69
  10. dinjesk
    KitKat Apr 9, 2016
    dinjesk , Apr 9, 2016 :
    You can flash the rom on stock recovery, but u wont have googles playstore as this is not in the rom.
    There for you will have to flash gapps and this is not possible on stock recovery.
    You will need a custom recovery for gapps
    So it's kinda up to yourself
    #70
  11. Saeed Ashif Ahmed
    #71
  12. Impulse37
    Thanks.. Actually just wanted to test it out for now. If I like it more than OOS, only then I'll unlock the bootloader. Even though i have heard that OP is not fussy about unlocking the Bootloader, I don't like doing that before warranty expires..
    Btw.. In your opinion, which ROM is better for daily use.. OOS or H2OS? Is there a significant difference in SOT or standby battery life?
    #72
  13. dinjesk
    KitKat Apr 9, 2016
    When u flash this rom, be aware of the chinese bloatware and not having any google apps or googleplay.
    Unlocking bootloader or root will not void warrenty. They even made a video how to ;)
    I have not tested OOS3.0 so cant comment on that. But h2OS was way better/faster then OOS2.2.1
    Battery life was quite good. i had sot around 6hour when i was on the rom.
    Now on cm13 by garak
    #73
    Impulse37 likes this.
  14. xenon005
    Yea doesnt matter how many times i enable it, it disables itself automatically when I clear them from recent app list
    #74
  15. dinjesk
    KitKat Apr 9, 2016
    Lock it in recents app list.
    #75
  16. aj0407
    aj0407 , Apr 9, 2016 :
    Wow ...using it since last 2hours and it feels great.
    Battery seems awesome. Finally something that can get the juice out of that battery..
    Few bugs are there.... Like they say keep discovering...... Never settle. ;)
    #76
  17. Maheshbujji
    Maheshbujji , Apr 9, 2016 :
    No
    #77
  18. zaphod-159
    Donut Apr 9, 2016
    #78
  19. zaphod-159
    Donut Apr 9, 2016
    zaphod-159 , Apr 9, 2016 :
    I am also having auto-hibernation issues with greenify. what do i have to enable apart from accessibility for it to work ?
    #79
  20. wjztusa
    Froyo Apr 9, 2016
    wjztusa , Apr 9, 2016 :
    then, it mean nothing for the people who outside the China
    #80
