16
Installation Instructions for H2OS v1.4 Marshmallow
  1. Jing Xiang
    Froyo Apr 14, 2016
  2. Leonhard Scheiber
    Froyo Apr 14, 2016
    Leonhard Scheiber , Apr 14, 2016 :
    4G is LTE, if you're not aware.
  3. itsmesdn
    Honeycomb Apr 14, 2016
  4. itsmesdn
    itsmesdn , Apr 14, 2016 :
    I think there is a slight difference. like GPRS (G) and EDGE (E) both are 2G technology, 3G and H+ both are 3G technology. Not sure though.
  5. Sachin8984
    Eclair Apr 14, 2016
  6. Sachin8984
    Eclair Apr 14, 2016
    Sachin8984 , Apr 14, 2016 :
    Use sideload for reinstall OS
  7. Sachin8984
    Eclair Apr 14, 2016
    Yes
  8. Sachin8984
    Eclair Apr 14, 2016
  9. Sachin8984
    Eclair Apr 14, 2016
    Can use stock recovery for flash gaaps , because don't want to root my phone
  10. Shahfaisalkhan
    Gingerbread Apr 14, 2016
  11. benzuk
    Eclair Apr 14, 2016
  12. grainehill
    Eclair Apr 14, 2016
  13. locxFIN
    KitKat Apr 14, 2016
    locxFIN , Apr 14, 2016 :
    Which gapps are you flashing? You can also disable md5 check in settings.
  14. grainehill
    Eclair Apr 14, 2016
    grainehill , Apr 14, 2016 :
    Sorry. Error code 64. It says wrong version. I downloaded arm 64 for android 6 stock.
  15. grainehill
    Eclair Apr 14, 2016
    New to this. While flashing gaps I get error code 64, wrong gaps version. I downloaded for arm64 android 6 stock.
  16. locxFIN
    KitKat Apr 14, 2016
    Check again, just in case. What's the name of the file you downloaded?
  17. grainehill
    Eclair Apr 14, 2016
    open-gapps-arm-6.0-stock-20160414
  18. dinjesk
    KitKat Apr 14, 2016
    dinjesk , Apr 14, 2016 :
    You downloaded the wrong arm version.
    You downloaded arm. But you need arm64
    locxFIN likes this.
  19. grainehill
    Eclair Apr 14, 2016
    Downloaded them again. still wrong. I get the same file name for arm or arm64.
  20. locxFIN
    KitKat Apr 14, 2016
    Can't figure out what's wrong there. Anyway, I've uploaded arm64 nano package (basically you can download the rest of Google apps you need from the Play Store): [deleted the file] hope that does the trick.
