16
Installation Instructions for H2OS v1.4 Marshmallow
  1. grainehill
    Eclair Apr 14, 2016
    Saeed Ashif Ahmed and locxFIN like this.
  2. Jing Xiang
    Froyo Apr 16, 2016
    Jing Xiang , Apr 16, 2016 :
    thank you flashed this rom alr
    Saeed Ashif Ahmed likes this.
  3. Jing Xiang
    Froyo Apr 16, 2016
    is it normal for the boot animation to be this long ?
  4. Jing Xiang
    Froyo Apr 16, 2016
    and how can i root my device after flashing this rom?
  5. DJSubterrain
    Ice Cream Sandwich Apr 16, 2016
    DJSubterrain , Apr 16, 2016 :
    He gives you instructions to flash SuperSU, SuperSU IS root.
    If you run any apps requiring root after installing SuperSU you should get a popup asking whether to provide root privileges for the app you are running.
  6. Jing Xiang
    Froyo Apr 16, 2016
    i cant seem to boot into twrp when pressing the power and volume down button ..... what is this problem?
  7. azlathi
    Froyo Apr 18, 2016
    azlathi , Apr 18, 2016 :
    Audio on here isas bad as OOS 3 for me. Is this a problem for anyone else?
  8. smrdelj
    Gingerbread Apr 19, 2016
    smrdelj , Apr 19, 2016 :
    Is there any way to change kcal screen settings in h2os (rgb, saturation, value, contrast)? Some app, or xposed module, anything?
    Obviously temperature control bar is not enough, not even close.
  9. si.ananth
    Eclair Apr 19, 2016
    si.ananth , Apr 19, 2016 :
    I hot my problem solved. But i want to know How to reinstall a os via sideload?
  10. RichtigerLurch
    RichtigerLurch , Apr 19, 2016 :
    Hey guys ja simple question:
    Is battery better as OOS 3.0.0??
    (screen on time)..
    Would be nice if someone report who used both roms...
    Thanks!
  11. locxFIN
    KitKat Apr 19, 2016
    locxFIN , Apr 19, 2016 :
    Go to install from USB (stock recovery) / advanced -> adb sideload (TWRP) and type "adb sideload nameoftherom.zip" on your command prompt. Might have to install adb drivers first. It's essentially the same as flashing in recovery.
    Wasn't on me. Some users have experienced better battery life, though, so I guess it depends on how you use it.
  12. RichtigerLurch
    Hmm okay.. I only use whatsapp, a little browsing but no gaming.. 2-3 YouTube videos but nothing special.
    50% wifi / 50 % mobile data
    This is my scenario...
  13. locxFIN
    KitKat Apr 19, 2016
    Pretty much similar to mine. Screen on drain was higher than on OOS (according to GSam Battery Monitor).
    RichtigerLurch likes this.
  14. RichtigerLurch
    Thanks buddy!! Maybe I give it a try :)
    So it's simply not a "heavy user" scenario? :)
    What are you running currently?
  15. SimonFullerImagery
    Jelly Bean Apr 19, 2016
    SimonFullerImagery , Apr 19, 2016 :
    Never figured how this becomes default, I mean who charges a phone via a computer anyway? Default should be 'file transfer' so who in the world do I phone about that? :)
  16. locxFIN
    KitKat Apr 19, 2016
    Probably not, then again I haven't pushed it to the limits on OOS either so I can't say which one would be more opyimized for that. Then network signal strength plays part etc.
    Right now I'm on OOS 3.0 Beta. Waiting for official CM13, then I'll probably try it along with bunch of custom ROMs.
  17. RichtigerLurch
    Me too. Waiting for official OOS mm and then custom roms with OOS 3.0 base...
    locxFIN likes this.
  18. preetfzr
    Eclair Apr 19, 2016
    preetfzr , Apr 19, 2016 :
    Guys, i have very wired situation with my phone. I on OOS 3.0 l, i tried several time to flash twrp recovery to get the root access. After flashing when i reboot my phone, it seems like, OS flash the stock recovery back to the device everytime and next time in recovery mode, it always get me to the stock one. I did same flashing procedure several time, but no help. Later after flashing twrp, i decided not to reboot fully but shutdown and tried directly enter to the recovery mode. Which really work. But still when i try to flash supersu, there os nothing actually happen in terms of command result just 'simulating partion' thats all! . And after again reboot, twrp gone! Please help.
    Thanks in advance
  19. McTaggerHK
    Gingerbread Apr 22, 2016
    McTaggerHK , Apr 22, 2016 :
    How's the GPS on this rom? I've been using the old 3.0 beta and the GPS lock is horrible on fitness tracking apps. Anyone using strava or something similar and can give me some feedback? Is it solid? I've been having trouble oos 3.0 where I loose a lock after about 5 to 10 min. Anything similar on h2os?
  20. rugo3232
    Eclair Apr 22, 2016
    rugo3232 , Apr 22, 2016 :
    I can't verify if the instrutions are "spot on" well written nonetheless!! Linear and concise :)
