123
[INSTRUCTION] CM12.1 NIGHTLIES OFFICIAL
  1. Harish19 Ice Cream Sandwich Jan 23, 2015
    Harish19, Jan 23, 2015 :
    Nightly itself getting much better day to day in updates ..am dreaming that cm12s will be a treat for Cyanogenmod lovers
    vigneshvar1 likes this.
  2. shashankpal Honeycomb Jan 23, 2015
    shashankpal, Jan 23, 2015 :
    How to remove the lock screen wallpaper?
    And also theme engine appears to be very buggy after few force closes, no matter which theme I install notification drop down dosen't get themed, it stays as stocked, any workaround for this?
    Edit : got the soln. For lock screen wallpaper.
  3. bhoopesh Donut Jan 23, 2015
    bhoopesh, Jan 23, 2015 :
    I faced error while installing Bacon latest built rom :
    e:error excuting updater binary in zip '/sdcard/download/cm-12-20150123-nightly-bacon.zip
    Can any one give a solution for that?
  4. OWAIS SHAIKH Donut Jan 23, 2015
    OWAIS SHAIKH, Jan 23, 2015 :
    Guys my opo is stuck on fastboot mode...while i was rooting it...plzz give some solution for it.....its urgent...
  5. Harish19 Ice Cream Sandwich Jan 23, 2015
    Hold down your power button for 20 sec or up till u feel vibration
  6. OWAIS SHAIKH Donut Jan 23, 2015
    thnxx dude.....thnx a lot
    can u snd me a link to unlock bootloader and install twrp recovery
  7. Harish19 Ice Cream Sandwich Jan 23, 2015
  8. Armsheezy Jelly Bean Jan 23, 2015
    Armsheezy, Jan 23, 2015 :
    Just follow the OP man!
  9. zeus.01.01.01.01 Lollipop Jan 23, 2015
    zeus.01.01.01.01, Jan 23, 2015 :
    you using cyandelta r or flashing the entire zip??
  10. nirpati Gingerbread Jan 23, 2015
  11. zeus.01.01.01.01 Lollipop Jan 23, 2015
  12. vigneshvar1 KitKat Jan 23, 2015
    vigneshvar1, Jan 23, 2015 :
    my guide is exactly for the same reason you mentioned and it happened because there is some problem with sdk which has caused problem for many.
    check my signature and follow it. surely it will solve.
  13. vigneshvar1 KitKat Jan 23, 2015
    wait a minute. is your bootloader unlocked or locked?
    if its unlocked then just press power button for 10secs(until a vibration comes) this will restart your phone.
  14. vigneshvar1 KitKat Jan 23, 2015
    OTA will download 250 mb daily (according to the build).
    cyan delta will download only the required files and merge it with the zip file that it has stored (maybe from just 15mb to 30 mb).
  15. parth.kharbanda Gingerbread Jan 23, 2015
    parth.kharbanda, Jan 23, 2015 :
    Hey bro chill man just sharing y are u going seroius
    tamila585 likes this.
  16. anupmahale Gingerbread Jan 23, 2015
    anupmahale, Jan 23, 2015 :
    If you are already on cm12 nightly then you can use either OTA or cyandelta or download zip and manually update via recovery. But if you are on cm11 then follow the steps in OP
  17. shashankpal Honeycomb Jan 23, 2015
    Anyone?
  18. ramamsub1 Donut Jan 23, 2015
  19. zeus.01.01.01.01 Lollipop Jan 23, 2015
    don't worry .. it will be fine .. just pre launch stress .... so a bit nervous ..!!:p:p:p
    Harish19 likes this.
  20. vigneshvar1 KitKat Jan 23, 2015
