123
[INSTRUCTION] CM12.1 NIGHTLIES OFFICIAL
  1. ramamsub1
    Donut Jan 23, 2015
  2. BadBoYAtif
    Gingerbread Jan 23, 2015
  3. evdobond
    Donut Jan 23, 2015
  4. zeus.01.01.01.01
    Lollipop Jan 23, 2015
    zeus.01.01.01.01 , Jan 23, 2015 :
    on a serious note cm12 is very good and the most stable among lollipop roms.
    however it still has some flaws but it sure a daily driver .
    you can try it if u can't wait more .. or maybe wait for cm12s which will be free of bugs and flawless (99%)
  5. Armsheezy
    Jelly Bean Jan 23, 2015
    Armsheezy , Jan 23, 2015 :
    Check if you are rooted or no. And if you have custom ROM or no.
  6. Armsheezy
    Its pretty good with latest nighlies. Its not as good as CM11s but I easily get 5 hours SOT after heavy usage of around 10-12 hours.
  7. zeus.01.01.01.01
    you can check by going into fastboot mode ..
    not sure though
  8. BadBoYAtif
    BadBoYAtif , Jan 23, 2015 :
    My one is rooted and I have bliss rom...
  9. BadBoYAtif
    didn't work
  10. BadBoYAtif
  11. shashankpal
    Honeycomb Jan 23, 2015
    shashankpal , Jan 23, 2015 :
    Yeah, no matter which theme I apply it just dosen't changes. It all happened after 1 theme got crashed then whichever theme I apply, notification drop down remain as stock blue one.
    Wiping cache didn't worked.
  12. Armsheezy
    To root and install custom ROM, first thing you have to do is unlock boot loader. As you have rooted and installed blisspop your boot loader is unlocked. Got it? :)
    BadBoYAtif likes this.
  13. evdobond
    Donut Jan 23, 2015
    evdobond , Jan 23, 2015 :
    @Armsheezy
    I got 51k+ benchmark (AnTuTu) in CM12 but 47k+ in CM11, yet using CM11 for its stability & battery backup.
    CM12 needs more time to become suitable for OnePlus One.
    Battery backup is most important factor while using such a monster gadget ! Hope Cyanogen will make it perfect shortly.
    I'm still happy in CM11 !!!
    Don't hesitate to assist me if stable version found to be useful for 1+1.
  14. zeus.01.01.01.01
    sir have patience .. i didn't give the full info there ...
    u have to go into fastboot and connect ur device with ur pc . (make sure drivers r installed on ur pc)
    open up cmd and then type "fastboot oem device-info"
    make sure your pc recognizes ur device as in adb interface .. u can see that by going into control panel then devices and u should see a yellow triangle. for more info contact @vigneshvar1
  15. Armsheezy
    Are bhai CM12 is still in nighlies. If you want everything perfect then wait for Official OTa ( not for Indian users), that is CM12s.
    Nighlies build are daily drivers no doubt but they don't have all features and everything is not well optimized. Hence battery backup is not as great as CM11s.
    I'll update you further about the stable builds.
    Also wait for milestone of CM12. It will be pretty much stable as CM11s
  16. BadBoYAtif
    Thanx
    Armsheezy likes this.
  17. zeus.01.01.01.01
    51k+ ??????????????????????o_Oo_Oo_O
    disable per app profile... ... and then see ..
    also don't rely on benchmarks completely ....
    also there r many benchmarks .. u can try those ..try vellamo
  18. evdobond
    Donut Jan 23, 2015
    Well, I know difference between stable & 'Nighlies' build....
    I don't wish to get a perfect at this time since it's 'Nighlies' but Hope to get solid build in next stable version....
    But, I will be very happy if OnePlus launches stable version of 5.0 for Indian 1+ in next few weeks.
  19. sriranganath HS
    Froyo Jan 23, 2015
    sriranganath HS , Jan 23, 2015 :
    @vigneshvar1 hey when m on a call if i get another call in between i get the call waiting thing as always but the problem is during that time i wont be able to hear anything from the other side n same happens even after the call waiting thing stops...!
  20. vigneshvar1
    KitKat Jan 23, 2015
    vigneshvar1 , Jan 23, 2015 :
    are you kidding? your bootloader is unlocked
