123
[INSTRUCTION] CM12.1 NIGHTLIES OFFICIAL
  1. vigneshvar1
    KitKat Jan 23, 2015
    vigneshvar1 , Jan 23, 2015 :
    bro same here!! cm bug
    wait for them to solve. Btw you can attend the second call easily right>.?
  2. parth.kharbanda
    Gingerbread Jan 23, 2015
    parth.kharbanda , Jan 23, 2015 :
    Does any one aware of cm12s official dates i heard it from someone its 26th is it i searched a lot but no luck found
  3. vigneshvar1
    KitKat Jan 23, 2015
    If its 26th then it will be a big treat ;) but as of i know, with the current status they will release only after feb 1st week. Now cm12 is crap when compared to cm11s44s ;)
  4. parth.kharbanda
    Can you tell y i m getting a score more than 52k in my antutu at nightly
  5. vigneshvar1
    KitKat Jan 23, 2015
    If your score is high that means your processing power and ram management has been tweaked better than before.
  6. parth.kharbanda
    Man vigneshvar1 you are pretty much famous in our indian threads i believe
  7. vigneshvar1
    KitKat Jan 23, 2015
    lol :D no bro
    jus helping out people with proper info
  8. parth.kharbanda
    Help me with one too
    Actually i am also a geek so can you just tell does your one plus one shows any problem with over flashing as my moto x does in hardware
    As hardwarevis not covered under warranty
    Thanks for your support
  9. Jazz365
    Honeycomb Jan 23, 2015
    Jazz365 , Jan 23, 2015 :
    Not sure how and why you guys are saying battery backup is not as good as cm11. I am getting way better battery backup on cm12 than cm11. Am I the only one? Oo
    Edit- Also it's smoother ,faster than the cm11. Apart from internal video codec I don't see any noticeable lackings, I may be missing something though.
  10. Armsheezy
    Jelly Bean Jan 23, 2015
    Armsheezy , Jan 23, 2015 :
    Unfortunately battery life is way better on CM11s. But CM12 is almost close to achieve cm11s battery backup!!!
  11. zeus.01.01.01.01
    Lollipop Jan 23, 2015
    zeus.01.01.01.01 , Jan 23, 2015 :
    I guess disable per app profile . u will see the change. But in lollipop one will get a high antutu score than kitkat . also don't blindly go by such tests . I trust vellamo more than antutu.
  12. zeus.01.01.01.01
    [Edited]
  13. Funk Wizard
    Lollipop Moderator Jan 23, 2015
    Funk Wizard , Jan 23, 2015 :
    What do u consider better, I get equally good response
  14. Faraz. Dipsite
  15. tamila585
    tamila585 , Jan 23, 2015 :
    bro.. @vigneshvar1 u too?? seriously CM12 is great other than battery backup.. we dont even have a milestone version yet but our nightlies are stable enuf for daily use. that in itself is a great thing. I have been using CM from the days of CM8. I know how long i had to wait for a stable version in order to get the phone working. Only after a stable version came, the nightlies will be useful. till that time the nightlies were a nightmare to us. everyday a new bug wil come and something which worked in previous build wil completely go off in the next build... compared to those nightlies, this CM12 nightlies are a hell lot better..
  16. vigneshvar1
    KitKat Jan 24, 2015
    vigneshvar1 , Jan 24, 2015 :
    so your a long time user of cm just like me but during those time cm was very much a smaller organisation but now its a lot more bigger than we can think. Use cm11s for a week and see bro, its near to perfect. There is something called management of ram,battery,processing,etc which is better in cm11 and not so good on cm12. And yes most of the bugs are fixed but still smaller ones left. So if they create cm12s build by this week also they will have to send it for google verification and google takes a bit of time to cross check things and allow cm to release the build via OTA.
    Its not like nightlies to build and release next day. So surely not before feb starting.(just my thought) maybe im wrong also because cm never tells anythin, not even a hint of whats going on.
    but cm12 is yet to really touch cm11s44s height of ROM management :)
  17. vigneshvar1
    KitKat Jan 24, 2015
    Armsheezy and Harish19 like this.
  18. cheguaravind
    Gingerbread Jan 24, 2015
    cheguaravind , Jan 24, 2015 :
    My cyandelta is not showing update 24th jan build. It's showing "zip not present in our database. Please wait some minutes and return here. If the problem persist, it could be a not supported or too old ROM."
    Actually I'm updating daily from 10january builds with cyandelta.
    Please help...
  19. cheguaravind
    vigneshvar1 likes this.
  20. Armsheezy
    Jelly Bean Jan 24, 2015
    Armsheezy , Jan 24, 2015 :
    Updated already! Its super damn smooth.
