123
[INSTRUCTION] CM12.1 NIGHTLIES OFFICIAL
  1. Armsheezy
    Jelly Bean Mar 4, 2015
    Armsheezy , Mar 4, 2015 :
    Settings -- Display and Lights -- Screen Color.
    Choose between Standard or Vivid.
  2. Armsheezy
    I liked the pebble time watch more than the existing android wear watches. :)
    The OS specifically
    zeus.01.01.01.01 likes this.
  3. Rohan Sharma
    Cupcake Mar 4, 2015
    Rohan Sharma , Mar 4, 2015 :
    This is quite ridicules that while editing my shipping address in Amazon the order got cancelled as the invite code showd by Amazon is used. I want an invite as I want to gift this one by weekend. Can Amazon and one plus one try to figure this issue out and get me my invite back.
  4. rahul2002j
    Froyo Mar 4, 2015
    rahul2002j , Mar 4, 2015 :
    Tried that and other changes already, no use.
    Looks more like a nightly issue. Hope tomorrow's update fixes it.
  5. vissup9
    Gingerbread Mar 4, 2015
    vissup9 , Mar 4, 2015 :
    I also faced the same problem.
    Un check sunlight enhancement.
  6. rahul2002j
    Froyo Mar 4, 2015
    Oops, didn't try that.. Was just trying to change contrast, brightness, etc.
    All good now... Thank a lot!!
    Armsheezy likes this.
  7. evo5ive
    Froyo Mar 4, 2015
    evo5ive , Mar 4, 2015 :
    Same issue, sunlight enhancement was the culprit. Hopefully they sort it.
  8. amit.bajoria07
    Eclair Mar 4, 2015
    amit.bajoria07 , Mar 4, 2015 :
    @vigneshvar1
    I have tried CM12 based rom now I want to revert back to CM11s until official cm12s releases ... I just have one question that how can i use that maxxaudio addon provided by you on first page ? I will revert back to 44s not 05Q, which does not have maxxaudio by default...
  9. Vicky_cbe
    KitKat Mar 4, 2015
    Vicky_cbe , Mar 4, 2015 :
    i tried the port on 44s and i got audio fx fc!! so for now you cant use!!
    it works well in cm12
  10. atulkhatri29
    Honeycomb Mar 4, 2015
    atulkhatri29 , Mar 4, 2015 :
    @vigneshvar1 bro i m currently using the exodus rom (yesterday's build) with franco kernal (r39) but still my sot is only 4 to 4 and a half hours.....can you please suggest what actually the issue is :(:(
  11. Vicky_cbe
    KitKat Mar 4, 2015
    post your battery stats and il help mate!!
    battery and sot
  12. pushkaljn
    Honeycomb Mar 5, 2015
  13. ansariamin
    Donut Mar 5, 2015
    ansariamin , Mar 5, 2015 :
    Yes my OPO also high color & contarst ratio after the nightly build update on Cyanogenmod 12, any display settings could not change it, hope its a update bug, gets rectified soon.
  14. anupmahale
    Gingerbread Mar 5, 2015
    anupmahale , Mar 5, 2015 :
    Contacts-ME-Edit-Edit the photo field
    pushkaljn likes this.
  15. rahul2002j
    Froyo Mar 5, 2015
    rahul2002j , Mar 5, 2015 :
    The solution's been provided above.
    Just Uncheck the sunlight enhancement.
  16. atulkhatri29
  17. jasvinder singh
    Donut Mar 5, 2015
    jasvinder singh , Mar 5, 2015 :
    that camera is taking blurred video's man can you give me any other camera app that can be used on cm 12 . I loved cm camera app is there some way by which i can get that app in cm 12 also Screenshot_2015-03-05-12-47-31.png Screenshot_2015-03-05-12-47-31.png
    sibiv7 likes this.
  18. Vicky_cbe
    KitKat Mar 5, 2015
  19. atulkhatri29
    atulkhatri29 , Mar 5, 2015 :
    I posted the screenshots in my reply to ur post,. Can you please have look that whats wrong with my battery backup in exodus:rolleyes::rolleyes:
  20. Armsheezy
    Jelly Bean Mar 5, 2015
    Armsheezy , Mar 5, 2015 :
    @vigneshvar1 @zeus.01.01.01.01 @cabhay and others
    I am on Exodus ROM lollipop one.
    I am facing lag while using the phone when I charge my phone. Using the original stock cable and charger that came with the box.
    Used another charger (Xiaomi) but still the same issue.
    Had the same issue in CM12 official nightlies. Also the lag occurs when phone heats up a little.
    What could be the issue. Are you guys also facing it?
    Do reply. :)
