Hey there guys,
The latest update from CyanogenMod is out and here we are with the zip file. This is the same exact OTA file but works on twrp also.
NO DATA WILL BE LOST AND IS FUTURE OTA SAFE
Download the incremental CM OS12 update file :
HERE [UPDATED] Big thanks to ravismiles4u
INSTRUCTIONS:
1. POWER OFF PHONE
2. PRESS POWER BUTTON AND VOLUME DOWN TOGETHER
3. IT WILL TAKE YOU INSIDE CM RECOVERY
4. SELECT APPLY UPDATE (NOT UPDATE THROUGH SIDELOAD) "0"--->INTERNAL STORAGE(WHEN YOU PRESS APPLY U WILL SEE 0,CLICK IT)
5. SELECT FILE
6. CONFIRM WITH YES or press Power button to apply the update
7. RESTART
POST 2 FOR UNLOCKED BOOTLOADER
POST 3 FOR PEOPLE COMING FROM CM12 NIGHTLIES OR WHO NEEDS WHOLE STOCK ROM.
Instructions (noob friendly)
1.Copy the downloaded zip to your phone (not inside any folder, just inside internal storage.)
2. Now power off phone then try to press power button and volume down together.
3. It will automatically go inside something called CM recovery, in that second or third option will be "APPLY UPDATE", select it.
4. Now press "from internal storage" now it will show 3 options select " 0 " now it is inside your internal storage just like file manager, now find this zip in that list(it will surely be there)
5. Select it and press "Yes" if it prompts else no need, it will start updating and come back to main menu.
6.Now press "restart"-->first option... That's it, Done!!
Hope this helps you guys in updating your phone to the latest version.
Regards
Vicky
Dont forget to click the like button if i helped you
happy updating allClick to expand...
