192
[Instructions]CM OS12 for all with "OK ONEPLUS"(LOCKED AND UNLOCKED BOOTLOADER)
  1. bloodycool
    Froyo Apr 14, 2015
    bloodycool , Apr 14, 2015 :
    Thanks. Which zip file did you downloaded, and from where?
  2. trueblue2
    Froyo Apr 14, 2015
    bloodycool likes this.
  3. Rashukhanna
    Ice Cream Sandwich Apr 14, 2015
    Rashukhanna , Apr 14, 2015 :
    how? please mention the steps u followed...
  4. jayztheone
    Eclair Apr 14, 2015
    shrey7 likes this.
  5. bloodycool
    Froyo Apr 14, 2015
    trueblue2 likes this.
  6. Niraj77747
    Gingerbread Apr 14, 2015
  7. Naman Bhalla
    Recognized developer Recognized Developer Apr 14, 2015
    Niraj77747 likes this.
  8. Niraj77747
  9. abhibnl
    abhibnl , Apr 14, 2015 :
    Don't get confused bhai. The correct size of every zip i've seen from the morning is 571mb including the one i downloaded.
  10. KfirLankry
    Cupcake Apr 14, 2015
    KfirLankry , Apr 14, 2015 :
    No need wipe somthing ? i must say i never root my phone, my phone is virgin :p, and noob instruction helps, but the question is if i need wipe
  11. ankitsoral
  12. shrey7
    Jelly Bean Apr 14, 2015
    shrey7 , Apr 14, 2015 :
    TWRP? what OS u had before.. OXYGEN?
    Do u still have root privileges?
  13. dvrp
    Eclair Apr 14, 2015
    dvrp , Apr 14, 2015 :
    Just now I was updated with TWRP. its perfectly installed and superuser also installed by TWRP. But cyanogenmod login was not working (Existing ID).....any help?
    shrey7 likes this.
  14. mramirkhan
    Honeycomb Apr 14, 2015
  15. mramirkhan
    mramirkhan , Apr 14, 2015 :
    No harm wiping cache, will just slow phone down on 1st boot as cache is rebuilt.
  16. nimish_rathod
  17. Gravity010
    Gravity010 , Apr 14, 2015 :
    Hi,
    I've tried doing this update, downloaded the file, copied to my phones internal memory too.
    But when i was on CM recovery, and tried to locate the zip file from internal storage , i am not able to find it in the list !!
    I copied the file again and tried, but still not able to locate the file from recovery.
    I have copied directly in internal storage and not in any folders.
    Pls help !!
    Nevabackdown likes this.
  18. manasjg
    Froyo Apr 14, 2015
  19. Nevabackdown
    Nevabackdown , Apr 14, 2015 :
    Hi updated the ROM but just looka t the screenshot
    Msging toolbar is overlapping with two different colors
    You were facing the same issue right
  20. Nevabackdown
    There will be a download folder select that
    In it you will find your file
