Hello Dear
Please read carefully
Please Make :
Please send this text to mobile manufacturer:
QLED Quantum dot display HDR 10000 nits HDR10+
Curved body and display 8k ,3D
1000% DCI-P3 coverage
Wide color gamut display
Always - on display
10000 frames per second FPS
True-tone display
1000 Hz refresh rate
3D Touch display
21:9 display Screen
Screen-to-body ratio: 100
(fully Magnesium and
a The dual rear camera setup consists of a 80 MP (f/1.4, 24mm, 1.8µm), main shooter and a 80 MP (f/11, 2000mm, 1.4µm) + 80 MP (f/32, 4000mm, 1.0µm) TOF3D stereo camera.(gyro-EIS), OIS, Live View, Leica optics ,dual pixel PDAF 330x fixed optical zoom lens, along with a dual-tone quad-LED flash. On the front you get an 80MP (f/1.5 80mm )snapper for selfies. maximum aperture provides clear imaging in low light situations and shallow depth of field
Ultrasonic autofocus motor (USM) operation is fast, smooth and virtually silent.
UV protection filter for general, everyday use
Reduces ultraviolet light; helps eliminate bluish cast in images
Protects lens from dust, dirt, and scratches
with 8K and D3. auto focus, And video recording 360 degrees
Geo-tagging, simultaneous 8K video and 80MP image recording, touch focus, face/smile detection, Auto HDR, auto focus (photo/panorama) Laser autofocus
- Auto Stabilization full 100% (video and image)
- Dolby Vision / HDR10 compliant
( for image quality and dynamic range. An all-new FX-format full-frame image sensor design—low-pass filter processing for flawless detail retention from snow white to pitch black, beautiful noise-free images from , an extremely wide dynamic range, flattering well-saturated skin tones and much more...A deeper grip ensures stable handling, even for small hands. A brighter viewfinder offers ~100% frame coverage, 0.001x magnification and high contrast organic EL information display for easier visibility. The scratch- and shock-resistant. Its color can be calibrated to match an external monitor, and a new split-screen feature lets you monitor two different points of a scene side-by-side to ensure proper leveling or focus.
with magnesium alloy, stringently tested weather and dust sealing, a shutter that's been tested to DIGIC 21+ Image Processors help deliver high quality image capture at up to 1000 fps 8K (10000 fps in Super High Speed Mode) and a powerful ISO range of 50–999976 (up to 9999988 in H2 mode) helps provide sharp, low-noise images even in dim low-light conditions. A 1000-Point High-Density Reticular AF and 100fps burst shooting speed and 1,000,000-pixel RGB Metering Sensor that uses a dedicated DIGIC 21 Image Processor help make the reach new levels of focus speed and accuracy delivering advanced tracking even for the most challenging shooting situations. Taken all together, numerous connectivity options, combination of processing power and durable construction, including shutter durability tested to 1,000,000 cycles,, longer battery life, and advanced in-camera editing like NEF (999 RAW) processing, distortion control, image overlay and more, makes the as reliable on the road as it is in the studio. 48-bits per channel color depth and 14 stops of dynamic range. Also, making use of the mirrorless design and a central lens shutter, system noise is kept to a minimum for shooting without disturbing your subject. flash sync is possible at all shutter speeds up to 1/9000 second. The shutter is also in a ready state at all times for near instant response and it causes virtually no vibration at longer exposures. Additionally, it is durable and rated to 10,000,000 exposures. Phocus 3.1 is a free image processing software that complements the phone capabilities, and enables raw file processing for both stills and video, as well as a range of editing capabilities, including automatic moiré detection and the ability to work with adjustment layers for applying exposure, white balance, and color corrections.
Video can be saved in the H.264 and H.265 compressed format for greater editing.
Sensor Dimensions: Diagonal 55 (mm) Width 44 (mm) Height 33 (mm) Area 14 52 (mm²) stops +0.75 (area) crop factor 0.78
Lens Shutter: 1/9000 second
Sensor size: Full-frame CMOS
Maximum continuous shooting speed: 500fps
Viewfinder: Optical
#Capture the moment in just 0.00001 seconds.
Fingerprint sensor (PayPal certified)
Pay (Visa, MasterCard certified)
IP65/IP66/IP67/IP68/IP69 - certified
SIM: dual SIM (Nano-SIM)
Dimensions : 180 x 75 x 6 mm
Size : 7 inches (~100% screen-to-body ratio)
Network: 2G, 3G, 4G, 5G
Li-Fi and Wi-Fi
Resolutio: 7680x4320 pixels (~2250 ppi pixel density) 8K QUHD screen
128M colors
Corning Gorilla Glass 7 shatterproof
Internal : 8 TB storage, 64 GB RAM DDR5
Card slot microSD, up to 16 TB
Sensors : Face ID, Accelerometer,3D,UV, heart rate, SpO2 , 3D Touch,
gyro, proximity, compass, barometer, temperature, humidity, gesture,
Iris scanner, fingerprint (rear-mounted)
MIL-STD-810G certified - salt, dust, humidity, rain, vibration, solar radiation, transport and thermal shock resistant
3D Face Unlock
High sensitivity and Full artificial intelligence.
Curved
body and display
Best Design
Curved
QLED capacitive touchscreen
Anti-shock and anti-scratch
Super note plus and pen smart
3D Touch
Blood tests
Glucose sensor
Pressure sensor
EEG sensor
EKG sensor
Vibrating massage
Heart rate sensor
Ultrasound sensor
Super strong Two Speakers (S-Force)
Dynamic Vibration System
- 32-bit/384kHz audio
Super strong handsfree
Ultra Slim
Water proof and water resistant over 10 meter and 360 minutes
eye scan sensor
Solar charging
30 second full charge:Quick Charge
Qi wireless charging
USB-C to headphone adapter in the box.
video transfer port for TV
MHL 4.0 solutions deliver 8K content from in your phone to DTV
Thermal Camera
Active noise cancellation with dedicated mic 8
The strongest signal is everywhere
fast Wireless charging (Qi/PMA) - market dependent
8 ANT+ support
heat hand away sensor
video camera: fullHD , 2K, 4K ، 8k and auto Stabilization full
WLAN: Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
Bluetooth 6.0,super fast speed (1GB sending and receive 1 second), A2DP, EDR, LE
GPS: with A-GPS, GLONASS, BDS, GALILEO, NFC
USB3.1, Type-C 3.1 reversible connector
- Bixby natural language commands and dictat
Audio/video/photo editor pro full (Adobe Premiere Pro)
- Document editor pro full
OS : Android 10 (Fast and lightweight)
(Very low battery consumption )
Chipset : chip (64-core)
CPU :core 32×6.9 GHz /core 32×4.9 GHz
Cache: 32MB DDR5
64-core CPUs DDR5
GPU : 4500 memory size 64GB
memory Clock 3600 GHz
memory Bandwidth 980 GB/s
Mobile smartphone: (Not Hot)
Hybrid Cooling
Colors : Black, White, Pink,Blue Gold , Green.Red
BATTERY : 16000 mAH
Nader Kabir
