International Roaming?? via OnePlus 7T
  1. fasal5995
    Cupcake Jun 30, 2020
  2. xnutzii
    Lollipop Jun 30, 2020
    xnutzii , via OnePlus 6T , Jun 30, 2020 :
    I mean... It almost says what it is in the pop up.
    You can get further information inside of the roaming "app" or whatever this actually is in this case.
    Or simple - this is roaming, with OnePlus powering it, more or less. You can get roaming over a data plan, which is ridiculously expensive in most countries, and get some good plans in others. If you have two sim cards installed, one will be disabled while enabling.
    I think this is the same as "E-SIM".
