13
Battery/Charging is anyone facing battery drainage problem in one plus 3t
  1. PrinceJaiswal986
    Donut Jan 10, 2017
  2. flycharlles78
    Eclair Jan 10, 2017
    G_T._A._CxNO, darrenhw and parharn like this.
  3. G_saransh_motiani_rPbZ
    Cupcake Jan 10, 2017
    G_saransh_motiani_rPbZ , Jan 10, 2017 :
    A lot.... Now a days my system is sucking battery like hell
    Morning 9'o clock i have charged it 99% and now it is 59%
    I dont know what is going on with my device
    F_Rajat_Chand_dzBX and parharn like this.
  4. G_Hemant_Sahani_eZfL
    Donut Jan 10, 2017
    parharn likes this.
  5. G_Hemant_Sahani_eZfL
    Donut Jan 10, 2017
    SSJK28071985 and parharn like this.
  6. aashman
    Honeycomb Jan 10, 2017
  7. G_Hemant_Sahani_eZfL
    Donut Jan 10, 2017
  8. Rishabh02honey
    parharn likes this.
  9. G_Hemant_Sahani_eZfL
    Donut Jan 10, 2017
  10. F_Alex_Ownz_Mgxk
    parharn likes this.
  11. G_Hemant_Sahani_eZfL
    Donut Jan 10, 2017
  12. spyros_kast
    Froyo Jan 10, 2017
    npandit likes this.
  13. spyros_kast
    Froyo Jan 10, 2017
  14. hadi.an
    parharn likes this.
  15. Kiran.a.joseph
    Jelly Bean Jan 10, 2017
    Kiran.a.joseph , Jan 10, 2017 :
    All those who are facing battery drain issue, please reboot into recovery mode and try deleting cache in recovery mode. If this still does not fix the issue, then please post some pics of battery stats
    It may be some of the apps running in the background which may be draining the battery. The most common one is fb. You can enable aggressive doze mode and apply app-launch restriction to reduce the high power usage of these apps.
  16. harald.servat
    Gingerbread Jan 10, 2017
    harald.servat , Jan 10, 2017 :
    uhmmm... that may require some clarification...
  17. G_globula_neagra_AjeA
    G_globula_neagra_AjeA , Jan 10, 2017 :
    My usage pattern has not changed, i don t see how deleting cache (all the stuff has to be downloaded/recompiled again ergo more data and cpu used) will actually help. Since many of us are experiencing the same issue is obviously that is something at the OS level that does not work properly in conjunction with some apps.
  18. iNtEnSePL
    KitKat Jan 10, 2017
    iNtEnSePL , Jan 10, 2017 :
    What the hell has 6GB RAM to do with battery draining issues? My phone has 6GB RAM too, you know. And it doesn't have battery issues.
  19. rhita5
    Eclair Jan 10, 2017
  20. iNtEnSePL
    KitKat Jan 10, 2017
    You are wrong and wrong.
    1. Cache consists of temporary data that was prepared for the app running on different version of OS. That means, that if something has changed in OS-app relation (how data is prepared, stored etc), then the cache data may be causing problems, as it's OLD cache for NEW OS-app ecosystem. Delete it, let the app prepare all data again, you won't have issues.
    2. It's not OS behaving wrong in conjunction with apps, its APPs working bad on OS. OS is the foundation (road), the app is merely one of many cars running on it. The road has changed, adapt your car, like everyone else.
