Is Éxodus still good ?
  1. Elas
    Jelly Bean Apr 29, 2015
    Elas , Apr 29, 2015 :
    Hey guys, is Éxodus rom still any good ? Because im getting only 3-4 sot with cod12 and i was thinking of Changing to à better battery rom..
    Yuvrajgharat likes this.
  2. tienpham3221
    Gingerbread Apr 29, 2015
    Elas likes this.
  3. fgaurano
    Ice Cream Sandwich Apr 29, 2015
    fgaurano , Apr 29, 2015 :
    Yesh
    Elas likes this.
  4. REDSON28
    Honeycomb Apr 29, 2015
    REDSON28 , Apr 29, 2015 :
    which build? im getting 4-5 SOT used to get 8-10 with the same tweaks on cm11s
    Elas likes this.
  5. DaxNagtegaal
    Marshmallow Apr 29, 2015
    DaxNagtegaal , Apr 29, 2015 :
    Exodus April 21st build is amazing
    fgaurano likes this.
  6. Elas
    Is latest build stable or you got a spécific build ?
  7. Farazahmed7
    Farazahmed7 , Apr 29, 2015 :
    Its the best out there. Better than cm 12.1
  8. marcvento12
    marcvento12 , Apr 29, 2015 :
    Im not getting a heavy battery..with no much of SOT.But the rom itself its georgeous...and works very good but install the 21 or 20 build not after because after roms there arent good as this builds...if you install it , listen to me...you will have a good/amazing battery ..but im not lucky heh
    Elas likes this.
  9. tienpham3221
    tienpham3221 , Apr 29, 2015 :
    I'm using April 26 build
  10. REDSON28
    i have this :p device is getting hot sometimes, it gets to 60+C just by playing clash of clans and i lose 1 percent every 10 sec, i'll do a clean istall
    Mohd Sultan likes this.
  11. tienpham3221
    I lose 1% from clash of clans after about 5 minutes of planning and organizing... A clean install might solve your issue
  12. DaxNagtegaal
    1% every 10 sec is bullcrap lol
    60C while having is perfectly fine.
  13. Elas
    Will try the 21april build if you say it's the most stable... Is it okay to backup data and apps with titanium on éxodus ? Because on cos12 it wasnt such à good idea...
  14. mwebsterpgh
    KitKat Apr 29, 2015
  15. Elas
    Which build ?
  16. Afzal Khan
    KitKat Apr 29, 2015
    Afzal Khan , Apr 29, 2015 :
    on which ROM r u..COS12/nightly 5.1 /Exodus?? m confused
    akulata likes this.
  17. ExpatZ
  18. Yuvrajgharat
    Froyo Apr 29, 2015
  19. marc.teixido
    marc.teixido , Apr 29, 2015 :
    Is the best. BTW if you're going to flash exodus, flash the 27th build
    Elas likes this.
  20. sachin surana
    Froyo Apr 29, 2015
