Is it worth changing from a one plus 6t to a 7pro?
  1. Idalbertopm22
    Cupcake May 24, 2019
    Idalbertopm22 , May 24, 2019 :
    Is it worth changing from a one plus 6t to a 7pro? Or is it better to wait if you get a 7t pro?
  2. Coastie
    Honeycomb May 24, 2019
  3. Idalbertopm22
    tengo un 6t, que puede ofrecer ma que pantalla y mento velociona que diga wao y como asi doble blanda de GPS?
  4. Jjallday
    Gingerbread May 24, 2019
    Jjallday , May 24, 2019 :
    for the screen quality, dual stereo speakers and 90hz I would say it's a rather hefty upgrade from the 6t. ultimately it's your choice.
  5. mrssml301
  6. pparmly
    pparmly , May 24, 2019 :
    I had the 6T and just upgraded. Reasons are the better screen, refresh rate and better sound from the speakers. Did I mention the screen?! Lol. The 6t is a great phone but this one is a bit better and as one who likes OnePlus and tech, it was an easy choice.
  7. Sargo
    Ice Cream Sandwich May 24, 2019
    Sargo , May 24, 2019 :
    its a big upgrade but comes with few different things such as curved screen and the pop-up
    I would recommend getting the regular 7 due to similar form factor, same selfie camera with no pop-up and having most of the updated specs from the pro like dual speakers or same updated fingerprint scanner
  8. Spelt
    Spelt , May 24, 2019 :
    Not really. If you already have a 6t I would stick with it. At least until the 7t comes out, if it does.
  9. Liehjan
    Lollipop May 24, 2019
  10. C3C0
    Froyo May 24, 2019
    C3C0 , May 24, 2019 :
    You should definitely go for it.
    Unprecedented 90Hz screen with AI controlled input handling.
    You won't need to touch the screen ever again. It handles all the touches for you.
    / sarcasm off /
  11. Idalbertopm22
  12. saikiran4ever
    Jelly Bean May 24, 2019
    saikiran4ever , May 24, 2019 :
    My opinion is NO. Not worth.
  13. OPAndrew
    Donut May 24, 2019
    OPAndrew , May 24, 2019 :
    Do you still need your 6T? I upgraded but I'm using both phones. Maybe sell your 6T, then pay the difference.
    It's a bit bigger but not much. Fingerprint unlock is much better. Stereo Speakers are much better. Camera is a lot better.
    But the 6T is still an excellent phone. It's a very personal choice.
  14. Tech Phoenix
    Froyo May 24, 2019
    Tech Phoenix , May 24, 2019 :
    I attended the event for the 6T and after comparing it to my 7 Pro, it seems that the 6T is great phone all around. It offers the amazing Oxygen OS experience as the 7 pro does. The only major difference would be is if you really want that wide angle camera. If you have a desire to shoot wide angle pictures then I would say yes, 7 Pro. If that doesn't matter to you, then I think the 6T should remain with you.
