2
Is My Orzly Screen Protector Too Small?
  1. yellowsnow4free
    Gingerbread Nov 9, 2014
    yellowsnow4free , Nov 9, 2014 :
    Hey everyone,
    Once again, here's me potentially being OCD.
    Anyway, I've read through a couple threads here that there are 2 versions of the Orzly tempered glass screen protector.
    I ordered mine late last month, in the USA, and it has a barcode ending in 891 (although the text on the box was more orange than yellow).
    I'm guessing I should have the version that fits better, not the one that is 1 to 2 mm too small on all sides.
    Some pics:
    The upper-right corner (2nd pic) has the largest gap; you can see it even with my Diztronic TPU, although it is quite small.
    Others have said their Orzly fits "like a glove", and this seems to fit quite well, but I wasn't sure if theirs looks like mine.
    Like I said, I may very well be over-thinking this, but if any Orzly owners can comment on the fit I'd really appreciate it.
    If better / different pictures are requested I can try and take them.
    Thanks!
    ursu' and abhimuktheeswarar like this.
  2. gautam.sharma
    Froyo Nov 9, 2014
  3. gmarch49
    Honeycomb Nov 9, 2014
    gmarch49 , Nov 9, 2014 :
    this seems a bit normal for the screen protectors ive had on other phones. I believe I have the same Orzly as you, but waiting on my OPO to arrive. i'll message you here when its here and installed when I get it if no one posts follow up pics
  4. gusuraman
    Community Veteran Nov 9, 2014
    yellowsnow4free likes this.
  5. peteryu
    KitKat Nov 9, 2014
    peteryu , Nov 9, 2014 :
    You see, if it's too big..........
    Screen protectors are usually a bit smaller than the actual screen (at least for all others I've seen)
    Mine is the same by the way
  6. yellowsnow4free
    Thanks for all the prompt replies everyone :) It seems like my Orzly is the correct size (yay!)
    I ordered mine on 10/17 from here: http://amzn.com/B00KQKATH8 sold by G_HUB
    I'm curious to see some pics of your Orzly installed, if it's not too much to ask :)
    gusuraman, I've been reading your posts here, and your feedback on my Orzly really helps; you are definitely the accessories master! :D
    I'd really like to see if I can get @Orzly on here to comment on this, although I'm quite confident now that mine fits correctly :)
    Thanks again everyone! ^_^
    gusuraman likes this.
  7. aspherical
    Jelly Bean Nov 9, 2014
    aspherical , Nov 9, 2014 :
    If the protector is exactly the same size as the screen, it's almost impossible to get lined up perfectly when putting it on. It also can interferes with cases that wrap around the edge of the screen.
  8. isen97
    Froyo Nov 9, 2014
  9. brolylss
    Froyo Nov 9, 2014
    brolylss , Nov 9, 2014 :
    it cant be
  10. ursu'
    Jelly Bean Jan 10, 2015
    ursu' , Jan 10, 2015 :
    mine's the same so did you received an answer from orzly?
  11. basrone
    basrone , Jan 10, 2015 :
    You can't go by that old adage "fits like a glove". Just ask O.J. Simpson.
  12. bkieu
    bkieu , Jan 10, 2015 :
    "If It Doesn't Fit, You Must Acquit":D
    basrone likes this.
  13. addam
    KitKat Jan 10, 2015
    addam , Jan 10, 2015 :
    My nillkin fits a lot better than that, now I'm glad I didn't go with the orzly. If that supposed to be a better fit I'd hate to see what the first version looked like.
  14. nunopinho1982
    Lollipop Jan 10, 2015
  15. Kutaro
    Cupcake Jan 10, 2015
  16. HeartOfStone
    Gingerbread Jan 10, 2015
    HeartOfStone , Jan 10, 2015 :
    Mine is the same, but when i put the Tudia case it's all great. :) Fits perfectly. Like an ice cream on a stick .
  17. amartens181
    KitKat Jan 10, 2015
  18. LibbyXCX
    Ice Cream Sandwich Jan 10, 2015
  19. ursu'
    LE: it seems you are right, there are 2 versions of the Orzly tempered glass screen protector, one that fits perfectly and one not so perfectly like your's and mine's :(
  20. AAddict
    Eclair Jan 11, 2015
    AAddict , Jan 11, 2015 :
    My Orzly fits the same as the OP's, it's exactly as I would expect. Right up the edge would be awful for a tempered glass protector.
