Is my UK Dash charger is 'upside down'?
  1. oneplusonesaleuk28
    Eclair Jul 4, 2016
    oneplusonesaleuk28 , Jul 4, 2016 :
    Hello
    I'm wondering if anybody's had the same issue as me with the UK Dash charger. When plugged into the wall it appears that the charger orientation is upside down judging by the logo and dash wording is facing the ground.
    Is there a possibility that the pins come apart so that both EU and UK pins could be used with the same block?
    I have attached images below.
    [​IMG] [​IMG]
    techygeek likes this.
  2. oneplusonesaleuk28
    Eclair Jul 4, 2016
    Bintang12 and MarkusRanz like this.
  3. Alvie
    The Lab - OnePlus 5T Reviewer Jul 4, 2016
    oneplusonesaleuk28 likes this.
  4. Magnetic Nerd
    Jelly Bean Jul 4, 2016
  5. crysen
    Gingerbread Jul 4, 2016
    Karthik Raghavan and jansvanda like this.
  6. G_Alex_Nilsson_sbHH
    Froyo Jul 4, 2016
  7. Scherpenseel
    KitKat Jul 4, 2016
    Rokni45, DEXY, sfomin and 7 others like this.
  8. napadalia
  9. tEf0o
    tEf0o , Jul 4, 2016 :
    If remove the earth pin that is made of 100% plastic, then it fits the correct way around.
    It's a bad s solution on a wrongly constructed item for UK.
    Don't do it, but it's a possible solution ;)
    Deactivated User likes this.
  10. grk007
    Honeycomb Jul 4, 2016
    grk007 , Jul 4, 2016 :
    Ha ha.. How annoying it would be seeing charger nor oneplus logo upside down.. ;);)
  11. oneplusonesaleuk28
    Eclair Jul 4, 2016
  12. oneplusonesaleuk28
    Eclair Jul 4, 2016
    I appreciate the thought behind this! :p I'll follow your guidance as well as my head and not break the pin off haha
  13. Hussar10a
    Eclair Jul 4, 2016
    Hussar10a , Jul 4, 2016 :
    Mine too, noticed when it arrived on Friday - my OCD has gone into overdrive ! I'd hoped the UK 3 pin plug just clipped or pushed on to a standard 2 pin charger block, but I haven't yet discovered a way to remove/rotate/refit it, so it'll just have to stay Australian I guess !
  14. oneplusonesaleuk28
    Eclair Jul 4, 2016
  15. G_Ryix_I_HgeC
    Eclair Jul 4, 2016
    DEXY, Hassan_Abdul and techygeek like this.
  16. bluewest8
    Hassan_Abdul likes this.
  17. Loveit
    KitKat Jul 4, 2016
    Loveit , Jul 4, 2016 :
    Oh man. This made me LOL hard. Here is my stunning combination that came with my OnePlus 2. To be fair I did order on the grey market.
  18. sbooth
    US Brand Ambassador Jul 4, 2016
    sbooth , Jul 4, 2016 :
    The same wall adapter body is used worldwide, but with different wall outlet pin-heads for different regions. For US outlets, the body and silkscreen text is correct, but for the UK/EU, it may be the opposite depending on the orientation of your wall outlet. In my opinion it is not a big deal.
    John j likes this.
  19. retroPKR
    Donut Jul 4, 2016
    retroPKR , Jul 4, 2016 :
    I thought I was the only one, bothered by this !
  20. oneplusonesaleuk28
    Eclair Jul 4, 2016
