Is Oneplus 8 pro compatible with Sennheiser Momentum true wireless 2 earbuds ?
  1. Q1592473798001
    Cupcake Jul 14, 2020
    Q1592473798001 , Jul 14, 2020 :
    Hello All,
    Can someone please confirm if Oneplus 8 pro is compatible with Sennheiser Momentum true wireless 2 earbuds? Here is the link to view this.......https://en-us.sennheiser.com/momentumtruewireless-2
    I want to buy that but before that, I want to double-check with you all.
    Also, is Oneplus 8 pro compatible with
    Sony WF-1000XM3 Industry Leading Noise Canceling Truly Wireless Earbuds, Google Pixel buds, and Bose earbuds?
    https://www.amazon.com/Sony-WF-1000...594743467&sprefix=sony earbuds,aps,188&sr=8-3
    Appreciate your help and support.
  2. sephstyler
    Froyo Jul 15, 2020
    sephstyler , Jul 15, 2020 :
    Is there any reason why you would believe them not to be compatible? All 3 (sennheiser, sony, and Oneplus 8 pro) have bluetooth, so there isn't any reason why they may not work?
  3. Q1592473798001
    Cupcake Jul 15, 2020
    Q1592473798001 , Jul 15, 2020 :
    I brought Google Pixel earbuds and used it for a week but it didn't work well. It used to get disconnected after running for a while and also sometimes either or one of the buds (left or right) used to stop working. Hence, I had to return that. I guess even if the buds are 5.1 compatible, still that's not the only reason you have to check codecs and supported profiles. Based on the codecs, I know that Oneplus 8 pro and Sennheiser earbuds specifications are matching but it doesn't say it supports A2DP which is why I am little concerned.
  4. Jose_Lizarazo
    Gingerbread Jul 15, 2020
    Jose_Lizarazo , Jul 15, 2020 :
    I have the Sennheiser MTW 2 and I can confirm they are compatible with the OP8 Pro with the AptX codec, which is better than most.
    I didn't buy the Sony because they lack this codec, but still you can connect them through AAC.
    Overall I can say I'm happy with them, but their weakest point is the ANC, which I consider really weak. The passive isolation is really good enough though, and the sound is really good, and it has been improving with updates in the last couple of weeks.
    Q1592473798001 likes this.
  5. Q1592473798001
    E1587459749968 likes this.
  6. Fenrisson
    Cupcake Jul 16, 2020
  7. Q1592473798001
    Fenrisson likes this.
