Is problem oneplus 5t via OnePlus 5T
  1. Khushal Kawale
    Cupcake Oct 19, 2021
  2. camohan
    Assistant Head Moderator Assistant Head Moderator Oct 19, 2021
    Best Answer
    camohan , Oct 19, 2021 :
    Hi there, for the first screenshot follow the below steps
    1. Go to phone dialer and type*#800#, enter
    2. Go to oneplus logkit
    3. Find Function switch
    4. Red screen assertion
    5. Turn it off
    Hope this helps.
    For the second screenshot, it is only a indicator that photos is draining you can select force stop now if you are not using the Google photos or ignore it.
  3. Khushal Kawale
    Khushal Kawale , via OnePlus 5T , Oct 19, 2021 :
    Thank you so much screenshot 1 Red screen problem solve but my device battery dream problem at it is
  4. camohan
    Great.
    I would not be worried about another one. Just press on ignore
