Is the charger cable same for all Devices from OP 3 to 7t
  1. ANOOP GS
    Donut Oct 21, 2019
    ANOOP GS , Oct 21, 2019 :
    Hi this is a different kind of question
    I was using a one plus 3 before and now upgraded to 7t, but still using both the devices. The charging cable of my one plus 3 got breaked. Can i use the cable provided with the 7t for 3 as well. I mean just the cable, not the power brick adapter.
    Thanks
  2. Bouncer71
    OnePlus 7 Pro Sample Shot Photographer Oct 21, 2019
    Bouncer71 , Oct 21, 2019 :
    Yes, you can...!
    We got a 3/3T and 7Pro and charge them with with every supplied cable and charger...
    You won't get Fast Charge on the 3/3T with the 7Pro charger...
    But Warp Charging the Pro with a 3/3T cable works..
    So the cables are basically the same... ;)
  3. guanyu210379
    Jelly Bean Oct 21, 2019
  4. camohan
    Marshmallow Moderator Oct 21, 2019
    camohan , Oct 21, 2019 :
    Yes. Both the charging brick (adaptor) and cable are inter usable.
