is the charging port of oneplus 6T built well??
  1. F_Mostak_Ahmed_XAlq Froyo Nov 9, 2018
    F_Mostak_Ahmed_XAlq, Nov 9, 2018 :
    When I'm connecting my oneplus 6T with C port carging cable or headphones it is moving , looks like the built quality of charging port has problems, is it only for my case or everybody has the same isuue??
  2. GopalB. Marshmallow Nov 9, 2018
    GopalB., Nov 9, 2018 :
    A lil bit of movement is not an issue...
  3. F_Mostak_Ahmed_XAlq Froyo Nov 9, 2018
  4. AmanRaj7 Eclair Nov 9, 2018
    AmanRaj7, Nov 9, 2018 :
    now that you mention it, i connected the earphone connector and there was a lil movement. Will check it out with the charger once reach home and update. Not sure its some certain devices or every device.
  5. F_Mostak_Ahmed_XAlq Froyo Nov 9, 2018
    for mine both charger and headphones have movement when connected, I personally don't like something unstable, thanks
  6. F_Mostak_Ahmed_XAlq Froyo Nov 9, 2018
  7. Dhaval1819 Donut Nov 9, 2018
    Dhaval1819, Nov 9, 2018 :
    I'm also experiencing but it's not an issue to worry as the port locks on whenever you connect anything via the USB. The click sound is the locking sound of the port.
    stbn84 likes this.
  8. U1541761483902 Cupcake Nov 9, 2018
  9. F_Mostak_Ahmed_XAlq Froyo Nov 9, 2018
    it's like the teeth of old people, connected but lose
    TheBaconBox likes this.
  10. the_o2 Lollipop Nov 9, 2018
    the_o2, Nov 9, 2018 :
    Are you able to easily remove the charging cable or earphone from there?
  11. F_Mostak_Ahmed_XAlq Froyo Nov 9, 2018
    yes, can remove easily
  12. Liehjan KitKat Nov 9, 2018
    Liehjan, Nov 9, 2018 :
    Do you have a case that prevents the cable to be inserted properly.. It should move inside the port.. But you should feel the cable lock in place, I can hang my phone from the cable without it popping out.
  13. F_Mostak_Ahmed_XAlq Froyo Nov 9, 2018
    it's well connected and working properly, but the issue is it's moving and not stable like as iPhone. this is an issue of low built quality of c port . I can't post video otherwise I would post a video here.
  14. Liehjan KitKat Nov 9, 2018
    Every usb-c charging device I own let me move the cable around, it's not a snug fit.. Phone, headphones, powerbank.. I can also confirm that my gf's iPhoneX cable also moves inside the charging port.
  15. F_Mostak_Ahmed_XAlq Froyo Nov 9, 2018
    really? my iPhone cable is stable enough, even I can't move it a bit, where One Plus 6T C port is like as the teeth of old man , OnePlus need colgate toothpaste
  16. Budruel Jelly Bean Nov 9, 2018
    Budruel, Nov 9, 2018 :
    You repeat yourself.
    Stop talking about the elderly as something negative.
    We'll see if you get old with all the teeth, I'm sure they'll take them out of your mouth when you say something like that on the street.
    If everything works, stop crying like a dog in heat.
  17. F_Mostak_Ahmed_XAlq Froyo Nov 9, 2018
    you are talking like as a bug of drain, hope your family didn't teach you how to talk, I was just asking about an issue of my new device, you have no reason to react like this, who told you to come over my post??
  18. Budruel Jelly Bean Nov 9, 2018
    I hope that the elders of your family will find out what you write here, that they are probably the ones who have taught you to speak. Have respect for the elderly, for the members of this forum and for oneplus.
  19. F_Mostak_Ahmed_XAlq Froyo Nov 9, 2018
    With all due respect, I asked about an issue, but please check you first reply what you have said, I don't know you are from oneplus team or not, you need to learn how to talk otherwise shut your mouth off. First learn the manner and behavior... If oneplus has quality issue definitely I have the right to ask, who are you to stop me asking?
  20. Liehjan KitKat Nov 9, 2018
    So have you tried some other usb-c devices? now you are comparing lightning with usb-c, two completely different connectors..
