Is the power bank suitable for iPhone 6?
  1. amar.joshi1799
    Froyo May 27, 2015
    amar.joshi1799 , May 27, 2015 :
    Is it bad for the iPhone 6's battery or anything? Also how many charges do you think it will give it?
  2. sfomin
    Nougat May 27, 2015
    sfomin , May 27, 2015 :
    Why would it be bad?
    iPhone 6: 1810 mAh, 4-4.5 charges
    iPhone 6 Plus: 2915 mAh, 2.5-3 charges
    Lunatasian and Lingering like this.
  3. Marcoziezo
    Honeycomb May 27, 2015
    Marcoziezo , May 27, 2015 :
    I'm sure the Oneplus Power Bank will make your iPhone 6 explode!!
    Edit: to calculate how much charges the Power Bank will give your phone you just have to divide the capacity of the Power Bank by the capacity of the battery of your phone..
    For example: 10 000mAh / 3100mAh for the Oneplus One which makes 3 charges.
    caldrich, siocnarf13 and sfomin like this.
  4. naskogashi
    Gingerbread May 27, 2015
    naskogashi , May 27, 2015 :
    I wouldn't suggest it. It might transform your iPhone into a OnePlus one! Jokes aside don't worry the oneplus PowerBank won't harm your iPhone! :D
  5. gringoboy
    Lollipop May 27, 2015
    gringoboy , May 27, 2015 :
    I'd say they're ideally suited actually. Both massively overpriced. But you're safe to use it. Apple haven't invented their own electricity. Yet.
  6. sfomin
    Nougat May 27, 2015
    You have to consider the efficiency of the powerbank. I said around 77%-80%...
    The PB only gets you 2.5 charges for the OPO
    Takendown and ChrisTerp like this.
  7. Carlosfer
    Ice Cream Sandwich May 27, 2015
    Carlosfer , May 27, 2015 :
    10% faster electrons for only $599.99! Also in gold!
    gringoboy likes this.
  8. Marcoziezo
    That's true, i was only speaking theoretically ;)
    Thanks for telling me the efficiency, i didn't know it was so low ;)
    sfomin likes this.
  9. sfomin
    Nougat May 27, 2015
    Yeah, not the greatest efficiency
  10. benluca
    KitKat May 27, 2015
    benluca , May 27, 2015 :
    The power bank will work with just about any device. As to the iphone 6? Who gives a s.h.t?
    caldrich, Takendown and sfomin like this.
  11. t4ww4b
    Jelly Bean May 27, 2015
    t4ww4b , May 27, 2015 :
    Just look at the charger output and compare that with power bank of brand X.
  12. mnk007
    Cupcake May 27, 2015
  13. WolfpackN64
  14. return.of.octobot
    Takendown likes this.
  15. pablofg1978
    Head Moderator Head Moderator May 27, 2015
    pablofg1978 , May 27, 2015 :
    Moved to accessories.
  16. gusuraman
    Community Veteran May 27, 2015
    gusuraman , May 27, 2015 :
    Can i use it to charge my car battery?
  17. Tamashi
    Jelly Bean May 28, 2015
    Tamashi , May 28, 2015 :
    That wouldn't be the most efficient way, but if you can connect it, sure give it a try.
    gusuraman likes this.
  18. gusuraman
    Community Veteran May 28, 2015
    gusuraman , May 28, 2015 :
    Luckily the plug is not compatible :D
  19. Tamashi
    Use a micro USB to car battery switch! ;p
  20. Tamashi
    I wonder how many OnePlus One Powerbanks it would take to fully charge an electric car.
