Is there a good Lens Kit for our OnePlus 7 Pro?
  1. jjvoliver
    Froyo Aug 22, 2019
    jjvoliver , Aug 22, 2019 :
    I have been looking for ANY lens kit that I can use with my OnePlus 7 Pro, and have not have any luck.
    Mostly, I'm interested in a 15X (or something around that) Macro lens and an 18X (at least) Telescopic Zoom Lens.
    The fact is that, because of how the camera lenses are set up in our devices, it has become impossible for me to find a kit (or even individual lenses) that we can use. I believe the biggest issue is the clips used in these kits.
    If anyone knows about any options out there (Other than the "Moment" brand, which apparently is only for extra rich people with the case only costing US$150.00), I would really appreciate it.
  2. Bombeev
    Gingerbread Aug 31, 2019
    Bombeev , Aug 31, 2019 :
    I've been searching myself but have not found any budget kits that look like they would work.
    jjvoliver likes this.
  3. I1562508508254
    Donut Sep 6, 2019
  4. jjvoliver
    Froyo Sep 7, 2019
    jjvoliver , Sep 7, 2019 :
    Nothing other than the "moment" lenses, but it's just too much money.
  5. I1562508508254
    Donut Sep 8, 2019
  6. I1562508508254
    Donut Sep 8, 2019
  7. I1562508508254
    Donut Sep 8, 2019
  8. jjvoliver
    Froyo Sep 8, 2019
    jjvoliver , Sep 8, 2019 :
    Well, thank you. This link wouldn't work for me, as I would need Amazon US, not IT. However, your tip led me to look for monocular for phones in Amazon US, and it seems like this one would be a good choice: Check this out at Amazon.com Monocular Telescope, 12X50 High Power HD Monocular with Smartphone Holder & Tripod - [2019 Newest] Waterproof Monocular with Durable and Clear FMC BAK4 Prism for Bird Watching, Camping, Hiking, Match https://www.amazon.com/dp/B07D3RYXWN/ref=cm_sw_r_tw_apa_i_8ZeDDbS0ZRPJC
    I'll order it, and will let everyone here know if it's worth it. At 25 dollars, the pain isn't much.
    I1562508508254 likes this.
  9. jjvoliver
    Froyo Sep 11, 2019
    jjvoliver , Sep 11, 2019 :
    Just a quick pseudo-update.
    I ordered the monocular and should be delivered by tomorrow. Will update after trying it. Still need a macro lens as well, but I think we're in a good track.
  10. I1562508508254
    Donut Sep 12, 2019
    I1562508508254 , Sep 12, 2019 :
    hello, did you receive your order?
  11. jjvoliver
    Froyo Sep 13, 2019
    jjvoliver , Sep 13, 2019 :
    No, it was delayed until tomorrow. As soon as I try it, I'll upload some samples using it.
  12. jjvoliver
    Froyo Sep 14, 2019
    jjvoliver , Sep 14, 2019 :
    These are the samples.
    Granted, this was just a quick test, at night.
    Tomorrow I'll try some shots during daylight.
    I1562508508254 and script like this.
  13. script
    Nougat Moderator Sep 14, 2019
    Bouncer71 and jjvoliver like this.
  14. jjvoliver
    Froyo Sep 14, 2019
    I'll try to upload them before the day ends. My kids take all of my Saturdays, hehe.
    script and Bouncer71 like this.
  15. I1562508508254
    Donut Sep 14, 2019
    I1562508508254 , Sep 14, 2019 :
    many thanks..have a good day with you kids..!!
  16. jjvoliver
    Froyo Sep 14, 2019
    So, I decided to do my tests before the hounds of hell decided to start wreaking havoc.
    In all honesty, I believe we need to keep looking (at least fo me).
    This is a comparison, from the exact same spot, taking shots of one of my JBL speakers, using my Asus ROG without the monocular (left) and my OP7P with the monocular and the tripod (if you can call it that, since it's almost unusable because it's so flimsy).
    This was the first shot, no zoom.
    This was the second shot, at 3X zoom.
    I'll try again using my main tripod, and will also attempt to shoot some pictures with my Asus ROG and my wife's Pixel 3 XL while using the monocular (the experience should be somewhat better since it's a single lens phone).
    I hope this helps others in the community.
    Stay tuned for some more updates.
    insomniachou and I1562508508254 like this.
