Other Is there anyway to recover text messages after hitting Reset system setting on OnePlus 7 Pro?
  1. Speedex13
    Cupcake Sep 17, 2020
    Speedex13 , Sep 17, 2020 :
    123124124.PNG I thought that reset system settings would only reset the system settings just like in windows, and that erase everything was a factory reset. Is there anyway to recover text messages after hitting reset system setting?
  2. Artemus.
    Nougat Sep 17, 2020
    Artemus. , Sep 17, 2020 :
    Nope! Unless you backed them up, they're long-gone. Next time, consult the Internet before doing something like this.
  3. R1589967451685
    Cupcake Oct 22, 2020
    R1589967451685 , Oct 22, 2020 :
    I suggest you try recovery programs which can recover kinds of files from any devices. But you'd better recover them as soon as possible.
  4. dinbandhukumar
    Ice Cream Sandwich Oct 22, 2020
    dinbandhukumar , via OnePlus 7 Pro Mirror Gray , Oct 22, 2020 :
    did your back up setting was enable with Google account. if so then it will come back once you add your Google account.
    check the screenshot if your Google account was already added before reset. it will recover this much things automatically.
