Is thereany way to activate secondary lowlight (20MP) sensor manually?
  1. Subhajit Hajra
    Honeycomb Jun 13, 2018
    Subhajit Hajra , Jun 13, 2018 :
    The quality of lowlight photos have improved a lot over time in OnePlus 5T with better use of the lowlight 20MP sensor and better denoising algorithm.I think OnePlus should allow user to manually change the sensor with which they want to click their pictures especially in low light.I don't know if this sensor is used in OnePlus 6.If not then the same functionality maybe brought into OP 6 as well.
  2. Waveform Modifier
    Marshmallow Jun 13, 2018
    Waveform Modifier , Jun 13, 2018 :
    Try typing *#*#1597#*#* into the dialer.
  3. TheRealGamer
    Lollipop Jun 13, 2018
    TheRealGamer , Jun 13, 2018 :
    To clear the confusion
    >OnePlus 5 - Telephoto
    >OnePlus 5T - Low Light Camera (For Low Light)
    >OnePlus 6 - Depth Sensor (used for Portrait)
    Artemus likes this.
  4. mados
    Cupcake Jan 23, 2022
    mados , Jan 23, 2022 :
    This is great! (now how do you switch it back?)
    Edit - never mind, just close Camera. Thanks!
