issue in contacts app
  1. 617378
    Froyo Nov 16, 2017
    617378 , Nov 16, 2017 :
    suddenly showing multiple contacts of the same name on my oneplus 5..anyone facing issues with default contacts app?
    ss53915 likes this.
  2. M1510119772757
    Eclair Nov 16, 2017
    ss53915 likes this.
  3. cssrc1974
    Jelly Bean Nov 16, 2017
    ss53915 likes this.
  4. sagar9510
    Eclair Nov 16, 2017
    sagar9510 , Nov 16, 2017 :
    I was facing the same issue to fix this you just need to go to Contacts -> Settings -> Contacts Display -> Display Options -> customize, then select the contacs that you want to display in your list.
  5. 617378
    Froyo Nov 16, 2017
    no..then also if we search particular name then it will show 3-4 names as of paytm, whatsapp, duo seperately..it was not happening before..
  6. sagar9510
    Eclair Nov 16, 2017
    That is what was changed in this update they tried to customize contacts app. So now it is not clubbing all the same contacts instead they are being showed seperately. So if you select specific contacts for display then this issue will be fixed.
  7. 617378
    Froyo Nov 16, 2017
    its certainly not happening in my case
  8. ss53915
    Donut Nov 29, 2017
  9. ilaria988
    Ice Cream Sandwich Dec 7, 2017
    ilaria988 , Dec 7, 2017 :
    same issue here with my opx. all my contacts are messed up. different number for the same people, different surname for those people I save only with their name.. the number of the same people change from whatsapp to telegram to normal contact list...
    how can I resolve this chaos?
  10. ss53915
    Donut Dec 13, 2017
  11. Deactivated User
    Dec 13, 2017
