Issue in network ic via OnePlus 3
  1. Y@SHSHRIP@D
    Cupcake Sep 23, 2020
    Y@SHSHRIP@D , via OnePlus 3 , Sep 23, 2020 :
    Its a very serious issue in oneplus 6 motherboard .. the network ic is creating problem after 1.5 years
    Phone gets automatically restart and nevers shows network they frequently rebooting the phone until the battery goes die
    OnePlus service center says change the whole motherboard worth 17500
    Its really bad for me and those who had a OnePlus phones
    The oneplus should recall the customer who had this problem and fix it for free
    If you spending for premium product you will aspect good service
    I have also the oneplus 3 there is no problem in this handset
    Tejachar likes this.
  2. J1539594755074
    Cupcake Sep 26, 2020
    J1539594755074 , Sep 26, 2020 :
    i am facing the same problem but my phone shows network occasionally what could be the problem do i need to replace the motherboard?
  3. Y@SHSHRIP@D
    Cupcake Oct 13, 2020
    Y@SHSHRIP@D , via OnePlus 3 , Oct 13, 2020 :
    There is no fix for now you want to replace the whole motherboard cost 17000 other wise recycle it
    .. and now i am using realme narzo smartphone because OnePlus lost the trust
  4. Rubel7114
    Eclair Oct 25, 2020 at 3:59 PM
    Rubel7114 , via OnePlus 6 , Oct 25, 2020 at 3:59 PM :
    My OnePlus 6 is 1.5y old & it starts Network issue. It's network is unstable. It shows network but actually no call incoming and outgoing. I'm confused is it Hardware issue or not.
  5. drl431
    Nougat Oct 25, 2020 at 6:06 PM
    drl431 , Oct 25, 2020 at 6:06 PM :
    Try resetting the networks:
    Settings > System > Reset options > Reset WiFi, mobile & Bluetooth.
  6. Rubel7114
    Eclair Oct 26, 2020 at 4:11 AM
    Rubel7114 , via OnePlus 6 , Oct 26, 2020 at 4:11 AM :
    I have already done network reset, APN reset, change SIM slot, wipe cache, Factory reset. But nothing works!
  7. dhruvk12
    Donut Oct 26, 2020 at 10:38 AM
  8. Tejachar
    Cupcake Oct 27, 2020 at 3:17 AM
    Tejachar , Oct 27, 2020 at 3:17 AM :
    Same thing
