issue in Oxygen OS 10.3.1
  1. CVR91
    Cupcake Feb 22, 2020
    CVR91 , Feb 22, 2020 :
    team
    i update the system update to 10.3.1 after that my mobile is getting more heat. why it's happening
    I1575744569683 likes this.
  2. Kytharsis
    Nougat Feb 22, 2020
    Kytharsis , Feb 22, 2020 :
    Did you format after updating? Are you using intensive apps?
    Caomhin and DrJMun like this.
  3. CVR91
    after formatting only heating is reduced
  4. Kytharsis
    Nougat Feb 22, 2020
    Are you using intensive apps like games on high brightness?
    Caomhin likes this.
  5. CVR91
    No
  6. Kytharsis
    Nougat Feb 22, 2020
    Then... what are you doing with it that it's "getting more heat"?
  7. DrJMun
    KitKat Feb 22, 2020
    DrJMun , Feb 22, 2020 :
    You said "No" to question about intensive apps... did you check using Battery?
    Caomhin and Kytharsis like this.
  8. Amogh2711
    Cupcake Feb 23, 2020
    p4llysingh likes this.
  9. Kytharsis
    Nougat Feb 23, 2020
    Kytharsis , Feb 23, 2020 :
    I'm pretty sure there's been worse updates.
  10. Mangeshgupta
    Cupcake Feb 27, 2020
    Mangeshgupta , Feb 27, 2020 :
    slide baar converted to white in colour which i don't like.....when we search an app by typing we can't see alphabet in dark mode
  11. abhis_8009
    Cupcake Apr 5, 2020 at 6:36 PM
