Issue : Problem : Apps are not working properly in OnePlus 5 T in Oxygen 5.0.4
  1. sukhdevsinghir
    Froyo Apr 7, 2018
    sukhdevsinghir , Apr 7, 2018 :
    Dear Sir,
    OnePlus 5 T Apps are not working properly.
    Applications Not Working
    Most Applications not working.
    How to solve this Problem
    I already upgraded to Oxygen 5.0.4
    Please reply me about how to solve Apps related issues Problems
    or
    How to upgrade to Previous version Oxygen 4.7
    Please Reply
  2. buntycubal
    User of the Year 2017 Apr 7, 2018
    buntycubal , Apr 7, 2018 :
    Check for updates of that apps, if ur apps r updated, clear cache from recovery.......Turn off your phone then Press Power button and Volume down button to get into recovery menu.Select Language.
    Select Clear Cache/Data.It will navigate you to a menu where you will have seperate options for clearing cache and for clearing data.select Wipe Cache option and reboot it....
    DanielOr likes this.
  3. sukhdevsinghir
    Froyo Apr 8, 2018
  4. sukhdevsinghir
    Froyo Apr 8, 2018
    sukhdevsinghir , Apr 8, 2018 :
    after doing this
    still facing same issue problem
  5. the_reckoner
    Ice Cream Sandwich Apr 8, 2018
    the_reckoner , Apr 8, 2018 :
    Can you pick one application and explain what isn't working in that application?
    Intruder71 likes this.
  6. sukhdevsinghir
    Froyo Apr 8, 2018
    System Apps Applications are not working properly
    When I click on Apps then screen fluctuate and Apps automatically Stops Working
    While some System Apps does not open after click
    like
    Gmail
    when I open Gmail and click on the link in email then nothing happen next while sometime screen fluctuate and stops working
    How to solve this problem
  7. Lancelot_69
    Lollipop Apr 8, 2018
    Lancelot_69 , Apr 8, 2018 :
    Turn off your phone. Then volume button down and power button same time. This will take you to recovery mode. Select your language by using the volume button to scroll down and power button to select This will take you to the next screen. There you can select clear cache, only choose this one using power button. Then reboot
    Nick 59 likes this.
  8. sukhdevsinghir
    Froyo Apr 8, 2018
    I already done all of above steps
    But still facing same issue problem
  9. Lancelot_69
    Then your best solution is to factory reset because downgrade will not help you. Something has gone wrong and you will only carry the issue wherever you go.
  10. sukhdevsinghir
    Froyo Apr 8, 2018
    please tell me perfect way of factory reset
  11. Lancelot_69
    Turn off your phone. Then volume button down and power button same time. This will take you to recovery. Using the volume button scroll down to your language and select it with the power button. This will take you to the next screen. Scroll down to factory reset and select using the power button. From there the process will start.
    Nick 59 likes this.
  12. sukhdevsinghir
    Froyo Apr 10, 2018
    sukhdevsinghir , Apr 10, 2018 :
    after doing hard reset , still facing same issue
  13. Lancelot_69
    Lollipop Apr 10, 2018
    Lancelot_69 , Apr 10, 2018 :
    Ok that is a tough issue! Can you download this into your phone? https://downloads.oneplus.com/oneplus-5t/oneplus_5t_oxygenos_5.0.3/
    It is the previous version. If you can do it and follow instructions below. If you want to older find older and do the same.
    1) Download OnePlus 5T Rollback zip and stable OxygenOS zip file from above and save it on your internal phone memory.
    2) Shut down your device and enter recovery mode by long pressing the Power + Volume Down key simultaneously.
    3) Select “Install from Local” and choose the Rollback build to install.
    4) Now reboot your device into recovery mode and Wipe data cache and Erase everything(Music, pics, etc).
    5) Reboot your device again.
    6) Your device will boot with special Nougat build.
    7) Done.
  14. X1517396854503
    Honeycomb Apr 10, 2018
    X1517396854503 , Apr 10, 2018 :
    Well one is Samsung Health. It won't start doing anything until and unless we open the app. Tried everything, even the members here guided me but no result. It works in other chinese oem phones btw.
  15. AJITHKUMAR.K.K
    Gingerbread Apr 10, 2018
    AJITHKUMAR.K.K , Apr 10, 2018 :
    Please uninstall all the third party applications and reinstall normal Google applications. Then check whether the problem persists or not . If there is something wrong, approach the service centre. good luck.
  16. Seven1396
    Cupcake Apr 10, 2018
    Nick 59 likes this.
  17. Z1522689991831
  18. TheMystic
    TheMystic , Apr 10, 2018 :
    your ROM could have some corruption. download the ROM again from OnePlus website and flash it via recovery.
    wipe cache before and after flashing the ROM.
    install only the most essential apps and see if you still have the same problems.
  19. TheMystic
    check above.
  20. sukhdevsinghir
    Froyo Apr 10, 2018
    Please tell me Step by Steps , Details Procedure of downloading ROM
