Issue with Alert Slider via OnePlus 8T Aquamarine Green
  1. mahi214 , via OnePlus 8T Aquamarine Green , May 16, 2021 :
    Does anyone getting same issue in 8T.
    When I put my mobile in vibration mode 📳 or in a silent mode 🔕.
    It's displays the current mode like 'Ring', 'Vibrate', 'Silent'
    That displaying mode not disappears for almost 5 to 6 Secs.
    and
    Also when I turn off(Display off) the phone and put it on 'Ring', 'Vibrate', 'Silent' modes then it's keep on showing(Not disappears) until I turn my phone on.
    G_Mnk_Chowdary_ewDe likes this.
  2. Aaron2017
    KitKat May 16, 2021
    Aaron2017 , May 16, 2021 :
    It's the same on both my OP phones. If you change the slider while the display is off, it'll keep on showing. It's so you know it's set to a different mode in case you changed it without knowing you changed it (while it's in your pocket for example).
    Bobbie63 and McJader like this.
  3. mahi214 , via OnePlus 8T Aquamarine Green , May 16, 2021 :
    This bug needs to be fixed in upcoming update
  4. Aaron2017
    KitKat May 16, 2021
    Well, that's not a bug really, that's how they designed it i guess. You can always drop a suggestion via the feedback section or tool if you don't like it.
    Sheppards and Bobbie63 like this.
  5. mahi214 , via OnePlus 8T Aquamarine Green , May 16, 2021 :
    Well, then why it's not be like that for OP 5t
  6. Aaron2017
    KitKat May 16, 2021
    Because OP 5t isn't running the newly designed oxygen OS11
    Bobbie63 likes this.
  7. camohan
    Moderator Moderator May 16, 2021
    camohan , May 16, 2021 :
    Hi there, can you share a video or screen recording of the incident to help visualise more
  8. #8
  9. camohan
    Hi there, you can upload in gdrive or image hosting site and share the link.
  10. #10
  11. camohan
  12. smallsmx3@gmail.
    Gingerbread May 16, 2021
  13. IlWizardxp
    Froyo May 17, 2021
