Issue with Opo's orginial protector case
  1. Apteryx
    Jelly Bean Jul 9, 2014
    Apteryx , Jul 9, 2014 :
    ---------------------------------------- ! Important ! ----------------------------------------
    There is a problem with this case that you should know, it's related to the phone...
    It's actually about the fact that the screen is higher than the level of the edges...
    And the original cover isn't enough high to protect the screen, you can clearly see :[​IMG] see it here :
    In this case, a front drop would be very very bad for your screen, and notice that the screen is actually LTPS IPS with TOL, so if you break it, you have to replace ALL the screen, not only the glass... that's a big point, but you don't have to worry if you have the good protections...
    I searched a good "alternative" to this cover, it found this : [​IMG]
    Price : 2x cheaper, EUR 4,99.
    It's available on multiple colors such as :
    - White, Blue, Black (light black) and Pink for our dear ladies ;)
    http://goo.gl/D8vkPv
    Need help ? Ask me :D
    By the way : there is another thread from me for screen protectors :)
    Edit : Another solution is Nillkin frosted shield here
    oscarvanl likes this.
  2. JAIGON
    Ice Cream Sandwich Jul 9, 2014
  3. Apteryx
    There are several options, I can found another for you....
  4. JAIGON
    JAIGON , Jul 9, 2014 :
    Already using Nilkin's frosted shield, you should put it in your post
    Apteryx likes this.
  5. Apteryx
    done
  6. Apteryx
  7. dannymx
    Honeycomb Jul 9, 2014
    dannymx , Jul 9, 2014 :
    Great thread.
    I noticed a few things about the OnePlus case:
    - Doesn't have enough grip to protect the phone, it will come off if you drop the phone.
    - Doesn't protect the screen, since the screen is higher than what the cover covers.
    I think I'm gonna regret my purchase (I bought the Clear Case).
    I bought the case because I thought it was TPU, this image was a little bit deceiving to me:
    Apteryx likes this.
  8. Apteryx
    Jelly Bean Jul 10, 2014
    Apteryx , Jul 10, 2014 :
    this one seems great ! [​IMG]
    Edit : With Rinoshield I might be very though !
  9. thyviper
    thyviper , Jul 10, 2014 :
    getting tired of knowing all opo issues :(
  10. Apteryx
    it's more about the cover, just buy another one instead of the original cover
