issue with screen cast
  1. Akkiz_ininstaz Froyo Aug 10, 2018
    Akkiz_ininstaz, Aug 10, 2018 :
    I'm not being able to cast my screen to smart tv or laptop from my OnePlus 6 where as its working fine on my brother's s8+
  2. OnePlus.Nene Honeycomb Aug 10, 2018
    OnePlus.Nene, Aug 10, 2018 :
    You mean you're not able to connect to your smart TV at all? Or is it a specific app that you're not able to cast on TV?
    BeingIncog likes this.
  3. Akkiz_ininstaz Froyo Aug 10, 2018
    im not being able to connect to my smart tv at all .. i tried it with my laptop too ..still it doesn't connect..
  4. OnePlus.Nene Honeycomb Aug 10, 2018
  5. Ace_rickslick Donut Aug 10, 2018
    Ace_rickslick, Aug 10, 2018 :
    Under Settings > Display > Cast > Enable wireless display (option is in the 3 dot menu).
    Hopefully this will resolve your screen casting issue.
  6. Akkiz_ininstaz Froyo Aug 10, 2018
  7. Akkiz_ininstaz Froyo Aug 10, 2018
    its already enabled .. ive tried everything
  8. RaviDevarakonda Cupcake Aug 10, 2018
    RaviDevarakonda, Aug 10, 2018 :
    generally, we have to allow our device on the smart TV. please check the attached devices on your TV. probably that might be the issue.
  9. Akkiz_ininstaz Froyo Aug 10, 2018
    no notification is being shown on tv... im being able to connect s8+ on the same tv with ease
  10. RaviDevarakonda Cupcake Aug 10, 2018
    just check the devices please. I have a Samsung smart TV curved n it works good. Allow access... always ask... might be helpful if you can check. it won't be issue with device mostly. otherwise better to approach service centre
  11. OnePlus.Nene Honeycomb Aug 10, 2018
    I have also successfully used the same method mentioned above with my home theater system and haven't faced issue. But I do have one issue where in I'm unable to view Amazon prime videos by this method since the latest update. Earlier it used to work fine but now it doesn't only the audio is heard. video is a blank screen only for amazon prime app.
  12. VILAS1976 Cupcake Dec 9, 2018
    VILAS1976, Dec 9, 2018 :
    I am facing the same issue as whenever I cast my OnePlus6T to my LG smart TV, using any apps, I can only hear audio but can't see video. This happens not only for Prime Video but also for Netflix, hotstar, airtelTV etc. YouTube works fine and any pictures I can cast without issues. please let me know if your problem was resolved OR let me know the solution to my problem
  13. OnePlus.Nene Honeycomb Dec 9, 2018
  14. VILAS1976 Cupcake Dec 9, 2018
    ah ok, so it seems they removed. however it's not only Primevideo but none of the app based video streaming is working like hotstar, Netflix, AirtelTV etc. not sure if this is all same issue
  15. Shield98 Honeycomb Dec 9, 2018
    Shield98, Dec 9, 2018 :
    http://bfy.tw/1Qi0
    DRM
  16. Shield98 Honeycomb Dec 9, 2018
  17. OnePlus.Nene Honeycomb Dec 9, 2018
    OnePlus.Nene, Dec 9, 2018 :
    Well it's just OnePlus 6 so far I guess probably 6t too. The other phones I tried are able to cast it (Redmi 4, Honor series, Poco F1). So it's not like Amazon removed this option from their app altogether since there are so many models across manufacturers that can still do it on their most up-to-date app. And I highly doubt Amazon did this only for OnePlus 6 models!
  18. VILAS1976 Cupcake Dec 9, 2018
    hmm. then this seems to be a bug probably OnePlus6T should fix. Yes, as I mentioned earlier, my old Moto G5 used to cast all these apps successfully
