9
Issue with WiFi connectivity after Android 10 update on One Plus 5T via OnePlus 5T
  1. Prateek2491
    Eclair May 27, 2020
  2. G_Akash_Siddhu_pkUN
    Gingerbread May 27, 2020
  3. Sid_Ck
    Ice Cream Sandwich May 27, 2020
  4. Prateek2491
    Eclair May 27, 2020
  5. Gow Tham
    Cupcake Jun 7, 2020
    Gow Tham , via OnePlus 5 , Jun 7, 2020 :
    Even am facing the same issue. After few research found that the first ever update on android 10 for all the model facing this issue. Especially wen connecting to 5hz network.
    Hope OnePlus team will sort out these bugs and will release the second update soon.
  6. babnik80
    Froyo Jun 8, 2020
    babnik80 , via OnePlus 5 , Jun 8, 2020 :
    After i updated, i have this problem too. when i am vonnected to a not to strong wifi, my phone always gets disconnected and it reconnects all the time.
    BROUKZ likes this.
  7. dimis2000k
    Donut Jun 8, 2020
    dimis2000k , Jun 8, 2020 :
    yes i have the same issue! I believe it happens when there is more than one WiFi networks available which the phone can connect to, but i am not sure.
    i also tried to forget the network and re add it but now, it cannot join it. it just says connecting for a second and then it stops.
  8. P1511855928889
    Cupcake Jun 18, 2020
    BROUKZ likes this.
  9. Praty_28
    KitKat Jun 18, 2020
    Praty_28 , Jun 18, 2020 :
    Im facing this issue since 2 years on my OnePlus 3T...Get OnePlus to fix it now or it will never get fixed.
  10. sherin.real1
    Cupcake Jun 20, 2020
  11. mhmtgkgl
    Cupcake Jun 23, 2020
  12. O1592446886477
    O1592446886477 , Jun 23, 2020 :
    Same problem. Is there any way to contact 1+ to complain? This is a pretty major issue.
  13. Waveform Modifier
    Marshmallow Jun 23, 2020
    Waveform Modifier , Jun 23, 2020 :
    Yes, it is called the feedback forum. As this is mentioned on every single update threads (both stable and beta) to where all bug report, suggestions, and complaints goes.
    https://forums.oneplus.com/feedback
    PokiX likes this.
  14. O1593929137806
    Cupcake Jul 5, 2020
    O1593929137806 , Jul 5, 2020 :
    My wifi connection drops constantly since the Android 10 update. I need to use wifi as mobile coverage at my home is very weak. I have to reconnect wifi every few minutes, 55 to 30 times an hour.
    BROUKZ likes this.
  15. Waveform Modifier
    Marshmallow Jul 5, 2020
    Waveform Modifier , Jul 5, 2020 :
    Read the post above to where you should post instead.
  16. K_M9
    Cupcake Jul 7, 2020
    K_M9 , Jul 7, 2020 :
    Even I'm facing same issue wifi drops suddenly and reconnect, even despite of having strong wifi and just few feets away from my wifi router with no walls in between it still drops and reconnects again. OnePlus should fix this ASAP possible it's so annoying
  17. varadharajanv
    Cupcake Jul 9, 2020
    varadharajanv , Jul 9, 2020 :
    Even I am facing this issue after the Android 10 update. wifi disconnects frequently and I have to connect manually again.
    BROUKZ likes this.
  18. BROUKZ
    Cupcake Jul 10, 2020
    BROUKZ , Jul 10, 2020 :
    I can't activate mic on cod mobile game too, plus wifi issues , rest ok
  19. U1511510067572
    Cupcake Jul 11, 2020
  20. B1593640859726
    Cupcake Jul 13, 2020
    B1593640859726 , Jul 13, 2020 :
    Hey guys, i have This same issue and i have this recorded on my One plus 7 pro if the staff would like to see
