Issue via OnePlus Nord
  1. Q1600762491112
    Cupcake Mar 20, 2021
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Mar 29, 2021
    Caomhin , via OnePlus 6T , Mar 29, 2021 :
    Try to Optimize the phone, this helps with Lag, Freezing, Heat, Battery Drain and much more.
    Clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Android may take a few days to optimize those apps after setting them to Optimize depending on your usage of those apps. A10 & A 11 have their own learning curve.
    After a couple of days, Check App battery stats at about 50% and see if there are particular apps using more resources than necessary.
    Guide to lower Battery Drain.
    ChriStefan likes this.
