Issues after CM 12.1-YOG4PAS2QL update
  1. wk0111
    Froyo Nov 5, 2015
    wk0111 , Nov 5, 2015 :
    Hi
    I had got CM incremental update recently. After the update I have noticed an issue.
    If I put the call on speaker or I initiate the call with speaker on, I am able to converse properly but during the call if I disable the speaker, my voice becomes too low to be audible to listener on other end of call. It becomes so low that I have to again put on the speaker or plug in the hands free.
    Kindly help. Thanks in advance.
  2. ratification
    Ice Cream Sandwich Nov 5, 2015
    ratification , Nov 5, 2015 :
    I don't know what's going on but I would suggest wiping cache if not fixed then downgrade to pervious built.
    Hopefully other members should be able to help you
  3. James Bond 007
    Honeycomb Nov 5, 2015
    James Bond 007 , Nov 5, 2015 :
    Then don't play with the speaker when you are talking. Bad habit. Bad student.
    On the other side I just updated to 3JL and nothing happened. Works flawless.
  4. sksuresh
    Cupcake Nov 5, 2015
    sksuresh , Nov 5, 2015 :
    Hi
    I had got CM incremental update recently.after update i have notice an issue.
    If I turn on mobile data, after few seconds mobile get rebooted couple times then after some time it will working.This issue happening frequently after this CM update.
    Kindly Help on this.Thanks in advance.
  5. wk0111
    Froyo Nov 5, 2015
    I wiped cache partition. Let's see if this works.
    ratification likes this.
  6. ambadi
    Donut Nov 9, 2015
    ambadi , Nov 9, 2015 :
    my phone reboot when wifi turned on..after the recent update..any solutions?
  7. MakaG
    Gingerbread Nov 9, 2015
    MakaG , Nov 9, 2015 :
    nop. wiping cache didnt work... :( plan b in progress ;)
  8. wk0111
    Froyo Nov 28, 2015
  9. Å¡£ā3¥ ‡ π0hā9
    Honeycomb Nov 28, 2015
    Å¡£ā3¥ ‡ π0hā9 , Nov 28, 2015 :
    I
    It works fine.... Just update to latest CM12-YOG4PAS3JL ... if it still doesn't works .. Because I can't help ... You ... Y just not try to reboot the device and check whether if it is working or not ???
  10. Deactivated User
    Nov 28, 2015
  11. Jakudk
    Cupcake Nov 29, 2015
    Jakudk , Nov 29, 2015 :
    After I updated it keeps asking me to update again and again. I have updated the same update 4 times now and I tried wiping cache and it's still askig me to update.
  12. Andre 15
    Eclair Nov 29, 2015
    Andre 15 , Nov 29, 2015 :
    Hey! I have the same problem and I don't know how to fix it.. Have you found a solution?
    Thanks!
  13. Wasim_Mohammad
    Gingerbread Dec 9, 2015
    Wasim_Mohammad , Dec 9, 2015 :
    Hi, I'm having the same issue and I tried rebooting, cleared cache nothing worked me. Let me know if you come across the solution. its very annoying I've to use speaker and the worst part is hands free doesn't work either with JBL headset.
    Thanks!!
  14. ajoseneves
    Froyo Dec 9, 2015
