Issues in Incoming & outgoing calls
  1. Rakul R S Cupcake Mar 15, 2019
    Rakul R S, Mar 15, 2019 :
    I am using OnePlus6T for the past 5 months.For the past 2 months,incoming and outgoing calls were not effective. If I am making a call, the opponent person voice is not audible.And if I cut the call and do again, then there will be no issue.Everytime it happens like this.I was completely frustrated with this. If I receive Incoming calls, voice is breaking continuously. I changed the sim in this mobile and tried again.The same issue is occuring.The problem is not with network.
  2. ngydat KitKat Mar 15, 2019
    ngydat, Mar 15, 2019 :
    You should probably contact support or go to the nearest service center (assuming you live in India)
    buntycubal likes this.
  3. Rakul R S Cupcake Mar 15, 2019
  4. ngydat KitKat Mar 15, 2019
