4
issues with 3.5.8 update
  1. blueblarog
    Cupcake Mar 28, 2017
  2. ab_11
    Cupcake Mar 29, 2017
    ab_11 , Mar 29, 2017 :
    Same problem here. Also, I am not getting any 4g network when I search for network operators.
    Is this a region specific update? That might be a cause of the problem.
    Can you tell me how to downgrade to the older OS?
  3. Tulasi1983
    Donut Apr 1, 2017
  4. chan222
    Cupcake Apr 16, 2017
    chan222 , Apr 16, 2017 :
    Tried this but volte option still not appearing, attached screen shots
  5. abhayakishore
    Cupcake Apr 17, 2017
    abhayakishore , Apr 17, 2017 :
    it worked thanks
  6. chan222
  7. realfamilyfun
    realfamilyfun , Apr 17, 2017 :
    Purchased my One+ 3T and decided to "Go Big". I love everything about the phone and the go big package BUT the tempered glass screen protector. Its way too narrow on the sides and way too long on the ends. Also, it has lifting edges around the device. When I contacted support thinking they would handle it, I was shocked to hear that, according to them, it was my fault! I emailed them and mentioned that Best Buy would stand behind their product if it was designed poorly and that they should too. They didn't give a hang nail. They cited fine print and blamed me again! The pictures in this post we're taken within an hour of opening the device. [​IMG] [​IMG] https://forums-images.oneplus.net/data/medal/600fe2dcd49d8.png
  8. chan222
    Cupcake Apr 21, 2017
  9. AaronStark171
    Ice Cream Sandwich Apr 21, 2017
    AaronStark171 , Apr 21, 2017 :
    So u just ask a question and answer it yourself?
    do you have multiple personality disorder or something.
  10. AaronStark171
    you applied the temperered glass yourself obviously it's ur fault genius.
  11. vr.dbest
    vr.dbest , Apr 21, 2017 :
    How to boot into safe mode. Plz guide
  12. vr.dbest
    Tried this. dint work. in fact nothing is working. don't know what to do. one plus guys don't care either
  13. vr.dbest
    Can someone please guide me on how to boot in safe mode?
  14. G CY
    Cupcake Apr 26, 2017
    G CY , Apr 26, 2017 :
    OnePlus 2 Safe Mode
    1. Power Down the OnePlus 2
    2. Once Off, Press and Hold the Power Button Until the Device Starts Booting
    3. As Soon as You See Android Booting Up, Let Go of the Power Button
    4. Once You Let Go, Immediately Start Holding Down the Volume Up and Volume Down Buttons
    5. Continue Holding These Two Buttons Until Android is Completely Booted
    6. Once You Reach the Lock Screen, Let Go of These Two Buttons and Unlock Your Phone Like Normal
  15. chan222
    Cupcake May 24, 2017
    chan222 , May 24, 2017 :
    Anyone care to respond on the issue?
  16. G_Manju_K_V_QdVY
  17. chan222
    Cupcake May 30, 2017
    chan222 , May 30, 2017 :
    Even in safe mode volte not visible, see screenshots, please suggest what is it that I am missing
  18. chan222
    Cupcake Jun 1, 2017
    chan222 , Jun 1, 2017 :
    issue for me fixed by doing a sim swap at Reliance digital store, however same sim used to work before 5.8.8, seems some caching problem during upgrade, i doubt so many people's sim getting damaged at 5.8.8 upgrade by chance, OP should look at this issue still, after every upgrade of OS, doing a sim swap can not be the solution
    #38
  19. chan222
    Cupcake Jun 1, 2017
    #39
