Sound Issues with Do Not Disturb Exceptions
  1. tushar1204 Cupcake Jan 12, 2019
    tushar1204, Jan 12, 2019 :
    Hi, I am not able to customize my Do Not Disturb Section's Exceptions. Whenever I go to Settings>Sound> Do Not Disturb> Exceptions, I am not able to customize the Calls & Messages, events and reminders Section. Whenever these two menu options are being selected, the Settings app crashes.
    When restored to factory settings, it works again, however, if back up is restored, it again fails.
    What's the root cause of this? Any tentative solution?
  2. Kytharsis Lollipop Jan 12, 2019
    Kytharsis, Jan 12, 2019 :
    It might seem the backup is involved. I suggest not restoring the backup if you can help it.
  3. tushar1204 Cupcake Jan 12, 2019
    Thanks for your reply. I restore my backup from Google Drive, which restores all apps, any other feasible solution that you would suggest I should do?
  4. Kytharsis Lollipop Jan 12, 2019
    Depending on what you restored, format it and start fresh. Install your apps one-by-one to see if it has to do with a bad app.
