4
JIO 4G(LTE) stopped working after CM 13 OTA update :/
  1. jaskiratmatharoo
    Cupcake Jul 26, 2016
    #41
  2. ftpankaj
    Froyo Jul 26, 2016
    ftpankaj , Jul 26, 2016 :
    Have you manually added apn, if not add the apn with jionet.
    #42
  3. junear
    Gingerbread Jul 26, 2016
    junear , Jul 26, 2016 :
    Guys with Android 6.0 not able to work with Jio SIM, try this out
    Go to phone dialer, type *#*#4636#*#*
    Click Phone Information
    Set the Preferred Network Type to LTE/GSM/CDMA auto (PRL).
    Turn off the radio and turn it on again.
    You can also turn Airplane mode on and then off
    Click Like if this works :)
    #43
  4. ayushbest1
    Cupcake Jul 27, 2016
    ayushbest1 , Jul 27, 2016 :
    Didn't work for me no network on reliance jio sim :|
    #44
  5. F_Abdul_Majid_VCsJ
    F_Abdul_Majid_VCsJ , Jul 27, 2016 :
    Bro Is Reliance Jio Is Working On Ox Os 2.1.4
    #45
  6. harsh431
    harsh431 , Jul 27, 2016 :
    I again confirm that Reliance Jio 4G WORKS perfectly with Oxygen OS 2.1.4. I have been using it since 3 days without any problem. Also, the cell reception is excellent. And, Jio 4G DID NOT WORK with CM 12.1 nor with CM 13.1.
    To sum it up:
    Working: CM 11,Oxygen OS 2.1.4
    Not working: CM 12.1, CM 13.1
    #46
  7. meprateek
    Honeycomb Jul 27, 2016
    meprateek , Jul 27, 2016 :
    Verified on CM-11.0-XNPH33R (CM is Cyanogen OS, don't confuse it with Cyanogen Mod)
    Downloaded older version from here
    http://forum.xda-developers.com/oneplus-one/general/official-cm11s-roms-ota-updates-t2906746
    Later in the day will flash Oxygen OS and post results.
    Also will try to flash the baseband as in CM11 to COS13 and see if Jio sim works or not.
    Screenshots for your viewing pleasure:
    Screenshot_2016-07-28-03-29-04.png Screenshot_2016-07-28-03-29-16.png Screenshot_2016-07-28-03-31-15.png
    UPDATE:
    Found the easy way out.
    Simply flash the modem from CM11 or Oxygen OS into your CM13 install. That's it Jio works just fine. Thank or like if this post helped you in any way. :)
    Cheers.
    #47
    soumyadeepdutta84 and arun320 like this.
  8. ayushbest1
    Cupcake Jul 28, 2016
    ayushbest1 , Jul 28, 2016 :
    Hey can you provide with the links ?
    #48
  9. op.pollicis
    Eclair Jul 28, 2016
    #49
  10. bcvsdgrf
    #50
  11. meprateek
    Honeycomb Jul 28, 2016
    meprateek , Jul 28, 2016 :
    @op.pollicis
    Volte is not supported (on both CM11 and OxyOS) as it is a feature implemented in software ( I'm no expert :p).
    Refer to this:
    https://www.quora.com/Is-VoLTE-a-ha...t-possible-to-install-VoLTE-into-the-software
    I guess there is a way to make voice calls using Jio-chat app.
    What I could achieve was to have a working Jio LTE connection on OPO running CM13 by making use of modems from CM11 and OxyOS 2.1.4
    And always remember to keep nandroid backup handy. All the best!
    #51
  12. meprateek
    #52
  13. satish kumar pathak
    satish kumar pathak , Jul 28, 2016 :
    @meprateek
    Sir, as all of us r having same problem( with Jio 4g) and u got a way out. Can u please give us step by step process . as we r not technical mind, we will be highly obliged if you can give us layman words with links to dnload the required softwares and ways to do it....please discuss in detail.
    Thanks
    #53
  14. Mehtab Singh
    Eclair Jul 28, 2016
    #54
  15. pablofg1978
    Spanish POC Assistant Head Moderator Jul 28, 2016
    #55
  16. harsh431
    harsh431 , Jul 28, 2016 :
    Can you please confirm what baseband you are using? A screen shot of the "About phone" page would be really nice.
    Thank You.
    #56
  17. Mehtab Singh
    Eclair Jul 28, 2016
    Mehtab Singh , Jul 28, 2016 :
    My phone is not rooted. Install all jio apps.
    #57
  18. F_Abdul_Majid_VCsJ
    F_Abdul_Majid_VCsJ , Jul 28, 2016 :
    Link Of Modem PLease Provide
    #58
  19. meprateek
    #59
  20. F_Abdul_Majid_VCsJ
    Cupcake Jul 29, 2016
    #60
