142
Join the OnePlus 6 and Bullets Wireless AMA now!
  1. Shadow0929
    Jelly Bean May 19, 2018
    Shadow0929 , May 19, 2018 :
    OnePlus has no interest in making a phone smaller than 5.5 inches so you're out of luck
    meatandy likes this.
  2. Shadow0929
    yes we will get the update
  3. Pratik2299
    Eclair May 19, 2018
  4. Shadow0929
    yes they are backwards compatible
  5. Shadow0929
    what? [e]1f602[/e][e]1f602[/e][e]1f602[/e] that's not how it works dude
  6. Shadow0929
    OnePlus doesn't have interest in making phones smaller than 5.5 inches
  7. rahulacr
    Eclair May 19, 2018
    rahulacr , May 19, 2018 :
    it means we have to settle with 480fpd instead of 960fps
    iNtEnSePL likes this.
  8. Shadow0929
    yes it does
  9. Shadow0929
    they where talking about this feature on the oxygen os open ears forum
    meatandy and the_reckoner like this.
  10. Shadow0929
    yes the headphones are backwards compatible
  11. Wuhfel
    Honeycomb May 19, 2018
    Wuhfel , May 19, 2018 :
    Yes, that's how it works, dude. Fortnite is releasing on all devices, however, those were not their original intentions.
    For example; Snap has repeatedly said that it will not optimize Snapchat for Android. However, since Google began working with them/paying them, Snapchat has since been optimized for the Pixel ONLY.
    This behavior is commonplace among app development.
  12. Fidda
    Gingerbread May 19, 2018
    Fidda , May 19, 2018 :
    I'm not sure what @Suresh07 meant by "support" but some features won't be supported.
    "These features are backwards compatible with Oneplus 5 and newer devices..." referring to the magnetic features.
  13. Shadow0929
    no, OnePlus said the 3 and 3T are receiving 8.1 and that's it for the phone, it doesn't matter how good the phone was OnePlus has a plan already for updates
  14. Shadow0929
    but why wouldn't they be supported? the 3,5,6 are in the same oxygen os version (except for the 3 which uses 8.0) it should be the same for all
  15. Fidda
    It makes sense for these features to be there, since you don't connect them directly it can't be hardware limitations. They'll probably implement it with later updates, but those were Carl's words.
    Shadow0929 likes this.
  16. Kalra78211
    Donut May 19, 2018
    Kalra78211 , May 19, 2018 :
    Why the battery is less in this.. beast mode should get good battery backup as compared to others... #getpeid
  17. Shadow0929
    I hope they do
  18. Shadow0929
    the OnePlus 6 has the same battery as the 5 and 5T and with the 845 processor your getting 10% improvement on the battery
  19. Fidda
    They rely on software to make the battery feel more lasting. The Snapdragon 845 also has some updates regarding the batter promising less battery usage.
    hadif786 likes this.
  20. Kalra78211
    Donut May 19, 2018
