153
Jumping from ColorOS to CM11S
  1. Busjen Ice Cream Sandwich Jun 25, 2014
    Busjen, Jun 25, 2014 :
    does anyone know if it makes a difference on your phone if you install via fastboot (fastboot.zip) or if you select recovery mode (signed.zip)
  2. procastinato Honeycomb Jun 26, 2014
  3. salawat Ice Cream Sandwich Jun 26, 2014
    salawat, Jun 26, 2014 :
    when you say "reboot , again in recovery..." do you mean after flashing the rom do we reboot to recovery straight from the coloros recovery or do we reboot the device first to set up then reboot to recovery?
    i hope i make sense.
  4. Busjen Ice Cream Sandwich Jun 26, 2014
    Busjen, Jun 26, 2014 :
    After flashing the rom reboot to recovery mode direct, NOT reboot the device to cm11s
  5. salawat Ice Cream Sandwich Jun 26, 2014
    yes i thought that was the case, it's just the commas were placed in the wrong place hence confused me. thanks though.
  6. Thoson97 Cupcake Jun 26, 2014
    Thoson97, Jun 26, 2014 :
    halle,
    i have a Oneplus One in 64GB white today become from China...now i want change from coluer os to CG11 beacause i need LTE and german ....can every one help me who can i load the files and what have i to do....
    very thx....
  7. Huffeez Froyo Jun 27, 2014
    Huffeez, Jun 27, 2014 :
    Thanks to these thread its really helpful and now my one plus start to use CM11s.
    (special thanks to member Graddy and Busjen)
    Here I provide the easy guide how to change your rom into CM11s
    1. Download first ROM from https://cyngn.com/products/oneplusone/ (I'm using the 1'st one)
    2. Reboot phone to recovery (volume down and power button together) choose rom and install.
    3. Done install ROM? now power off.
    4. Again (volume down and power button together) choose to wipe data, and then wipe chache.
    5. Done wiping? now reboot your phone, it takes a few minutes. Don't worry if it takes too long and TADAAA you now running CM11s.
  8. fatsmaximus Eclair Jun 27, 2014
  9. amjad_2020 Ice Cream Sandwich Jun 27, 2014
  10. Thoson97 Cupcake Jun 27, 2014
    Thoson97, Jun 27, 2014 :
    it works very fine ...very much THX....10 minute it was done...:)))))
    i hope my LTE is working too i dont test it this time :)))
    can update this version ?
  11. IwantanInviteplease Cupcake Jun 28, 2014
  12. Is two Ice Cream Sandwich Jun 28, 2014
  13. ronj999 Cupcake Jun 28, 2014
    ronj999, Jun 28, 2014 :
    HI idid as you say but when i press power +vol up i get fastboot not same as you say.can you help.thanks
  14. Ng Eddie Honeycomb Jun 28, 2014
    Ng Eddie, Jun 28, 2014 :
    I
    Are there any problems after changing to CM11S?. Thanks
  15. Ng Eddie Honeycomb Jun 28, 2014
    After you change it to CM11S,are there any problems? Thank you.
  16. Ng Eddie Honeycomb Jun 28, 2014
    I gets only one word.fastboot.I wait sometime and than press continually . It reboot as normal thus I am still looking for more info as to how to do it. Thank you.
  17. salawat Ice Cream Sandwich Jun 28, 2014
    salawat, Jun 28, 2014 :
    if flashing through recovery flash the first one as in the signed.zip one, if doing via fastboot, use the fastboot.zip ie - the second one.
    theprimogenitor likes this.
  18. Huffeez Froyo Jun 28, 2014
    Huffeez, Jun 28, 2014 :
    Hey man, there is no problem when I flash to CM11S.Everything's fine.
  19. ronj999 Cupcake Jun 28, 2014
    how long did it take to download on the phone
  20. ronela97 Gingerbread Jun 28, 2014
    aaronwong likes this.
