Just can't get really good battery life....
  1. snarfarlarkus
    Eclair Aug 15, 2015
    #41
  2. vcespon
    Gingerbread Aug 15, 2015
    vcespon , Aug 15, 2015 :
    Google play services have damaged even my current KitKat based ROM. Since a few days ago I get an error on Google Play services when GPS is ON. And this keeps happening after a full erase and reinstall of the ROM, which was has been working fine for months until a few days ago.
    Google is really annoying me, I don't even think about getting any other phone with Android L because all have the same problem of Google Play services or Android system taking more battery than the screen. This does not happen on previous Android versions, period. And I have had 10 Android phones until now.
    #42
  3. vcespon
    Because we are talking about screen ON time, and STANDBY duration. Of course if I turn the phone OFF it can stay that way for 100 years. Buy I need my phone able to get calls and messages, but without the battery dropping 5% every hour. Something that it is ******* possible with other phones, and with the OPO with Kitkat ROM. So poor battery life is a Android L problem.
    #43
    StijnIJskonijn likes this.
  4. StijnIJskonijn
    Eclair Aug 15, 2015
    StijnIJskonijn , Aug 15, 2015 :
    Ah i see :). Good luck!
    #44
  5. tautis011
    tautis011 , Aug 15, 2015 :
    You cant be doing anything wrong. The problem might be that you got an phone with battery defects.
    #45
  6. Mystel
    Eclair Aug 15, 2015
    Mystel , Aug 15, 2015 :
    Your phone's battery is fine. In normal usage I get the same SOT. Stop worrying too much about SOTs unless it is very low.
    #46
  7. royz0r
    Jelly Bean Aug 15, 2015
    royz0r , Aug 15, 2015 :
    styloking was bad for me tho. only 4 hours sot, with no gaming and brightness at 5 to 10 percent......
    #47
  8. DankMagician420
    DankMagician420 , Aug 15, 2015 :
    What's that? Never heard of that module before
    #48
  9. Dr. Indest
    Lollipop Aug 15, 2015
    Dr. Indest , Aug 15, 2015 :
    Puts your phone in deep sleep when the screen is off.
    #49
  10. Dr. Indest
    Most ppl avg 7-8 hours with it alone.... are you sure you applied the profile correctly?
    #50
  11. royz0r
    yes I did, i know how to apply them. select profile, then "V" then it"ll restart and then press "X"
    #51
    Dr. Indest likes this.
  12. ButterFlYnez
    ButterFlYnez , Aug 15, 2015 :
    My SOT is around 2-3hours, 3,5 max if I don't play any high framerate game... I run nightly bacon now with stock kernel. I'll try the AK kernel as well (can't hurt at this point).
    Edit: brightness is set at 5% all the time since it will significantly decrease my battery if I put it higher.
    #52
  13. DankMagician420
    I searched for it in the xposed app...can't find it
    #53
  14. Dr. Indest
    Play store
    #54
  15. Cboyd104
    Ice Cream Sandwich Aug 15, 2015
    Cboyd104 , Aug 15, 2015 :
    Where do u get profiles from?
    #55
  16. royz0r
    Google is your friend
    #56
  17. Cboyd104
    Aye but is there downloadable preset profiles? Can't find anything
    #57
  18. bubu83
    bubu83 , Aug 15, 2015 :
    rom sultan has very good battery life. Some users have come to 8 hours of screen.
    #58
  19. royz0r
    Omg i could find it so can you
    #59
  20. Nimagia
    Donut Aug 15, 2015
    Nimagia , Aug 15, 2015 :
    Try go on to your settings > Battery and check if an app is draining/ keeping your phone awake. Some apps have the ability to prevent the phone from sleep (keeping the screen on).
    I had this with the app Google Play services.
    To fix it all you need to do is edit the app's permissions in Settings > Privacy > Privacy Guard > Press and Hold (App Name) to open App ops > Change whatever you believe is making it drain battery.
    #60
