Just can't get really good battery life....
  1. 1pandaman
    Gingerbread Aug 18, 2015
    #81
  2. Dr. Indest
    Lollipop Aug 18, 2015
    Dr. Indest , Aug 18, 2015 :
    I am getting battery stats for you folks. So far...
    #82
    1pandaman likes this.
  3. 1pandaman
    1pandaman , Aug 18, 2015 :
    Whoa looking good so far which set up is this cause I'm getting 4 hours with ak kernel and styloking profile. Maybe I'm just to much of a power user :( I'm also using exodus but I doubt it's that
    might just need to get a phone like the innos d6000 hope not though OnePlus one is so nice
    #83
  4. JHong
    Jelly Bean Aug 18, 2015
    JHong , Aug 18, 2015 :
    How long have you been using your OPO? Do you use it as heavily as sfomin? The battery might be at the end of it's life for all you know.
    #84
    sfomin likes this.
  5. Dr. Indest
    Styloking, ak300 and CM 12.1.
    I know Exodus current builds yields less battery than CM 12.1 builds now (based on user feedback). Maybe the kernel is just undoing the crapjob Exodus is doing. Maybe I am just bias lol.
    #85
  6. Dr. Indest
    Also, make sure you are applying the profile right. It is super tricky to apply it right. Be sure to compare with the pictures.
    #86
  7. 1pandaman
    Either way I'll try cm12.1 soon it's just to much fun switching Roms lol
    #87
    Dr. Indest likes this.
  8. 1pandaman
    Pretty sure it's on fine but will double check
    #88
  9. Naveengnk
    Honeycomb Aug 18, 2015
    #89
  10. Dr. Indest
    #90
  11. 1pandaman
    By chance have you ever switched the battery in a opo I think I may have damaged it by doing bad charging cycles
    I like leaving it on a charger over night :/
    #91
  12. Dr. Indest
    Not me. I too charge overnight.
    #92
  13. Schrauff
    Schrauff , Aug 18, 2015 :
    HINT: there is a report button under every post. I wonder what it does...
    #93
  14. 1pandaman
    That actually doesn't work sadly just report to a moderator
    #94
    Yupet likes this.
  15. Yupet
    Honeycomb Aug 19, 2015
    Yupet , Aug 19, 2015 :
    I did realize that there is such a button, and I did report several times, but nothing happens...
    #95
  16. mentaribiru
    Donut Aug 19, 2015
    mentaribiru , Aug 19, 2015 :
    I can't set profile on synapse, when i choose the profile and press the V button, it wont restart and the profile is not set. Any suggestions?
    #96
  17. Aniketwastaken
    Donut Aug 20, 2015
    Aniketwastaken , Aug 20, 2015 :
    Once u click V, click on restore selected profile, then it will restart, after it does , press X. You are done :)
    #97
  18. vcespon
    Gingerbread Aug 21, 2015
    vcespon , Aug 21, 2015 :
    That looks much better, but it's sad that you have to install another kernel, an application and a profile that's complicated to get right to get NORMAL battery life. Why is this not implemented on the ROM code to begin with?
    I'm staying with my Kitkat ROM until Google stops messing around with Lollipop ROMs for the OPO. I could get a standby of one week with this ROM, and I usually get 6 - 7 hours screen on time.
    #98
  19. Two
    Honeycomb Aug 21, 2015
    #99
    cedalone likes this.
  20. cedalone
    Jelly Bean Aug 21, 2015
