50
Just recieved YOG4PAS3JL OTA
  1. stOk3d
    Eclair Nov 4, 2015
    stOk3d , Nov 4, 2015 :
    Anyone experiencing random reboots? I just got this update. Installed it hoping it fixes it but no luck. My phone runs on stock... Not rooted. Any ideas guys? Screenshot_2015-11-04-12-18-25.png Screenshot_2015-11-04-12-18-25.png Screenshot_2015-11-04-12-18-15.png
  2. armmani2001
    KitKat Nov 4, 2015
    armmani2001 , Nov 4, 2015 :
    which one? op2 or opx
    joao2008 likes this.
  3. R Reddington
    KitKat Nov 4, 2015
  4. lazloinsf
    Froyo Nov 4, 2015
    lazloinsf , Nov 4, 2015 :
    Got official OTA after manual check for updates -- did it's optimizing thing -- rebooted and as soon as I pattern unlocked, then noticed that NavBar icon bug not fixed, it spontaneously rebooted -- hoping it will stabilize now...
  5. xavtak
    Cupcake Nov 4, 2015
    deviantartjr likes this.
  6. gewoon_emile
    Froyo Nov 4, 2015
    gewoon_emile , Nov 4, 2015 :
    No shit. I just said that because it's the first time that the update tracker app didn't notify directly that there was a new update
    p2p likes this.
  7. arjanvlek
    Honeycomb Nov 4, 2015
    arjanvlek , Nov 4, 2015 :
    Well, because Cyanogen put a secret key on the fota page, and I came just home from work to add the data manually. We should all start decompiling update packages and look for the key. A whole new API has already been found by me but it is hindered by the rollout percentage just like the real phone updater app.
    jferraz likes this.
  8. armmani2001
    KitKat Nov 4, 2015
    I am completely lost now :p What are you trying to achieve? Somebody already posted all versions..
  9. omar2003
    Eclair Nov 4, 2015
  10. arjanvlek
    If we have the key, the app and the cyanogen-ota-bacon site will function automatically again which is MUCH better than the current situation. Remember that there are 10 different devices running Cyanogen OS that all get updates... As I'm busy it is not feasible to maintain them all manually. If this situation persists I will at least cancel the vps server and point the domain name to home hosting again as it is way cheaper.
    armmani2001 likes this.
  11. armmani2001
    KitKat Nov 4, 2015
    Ok now I got it.. Do you maintain update tracker app? :)
  12. arjanvlek
    Yes, i'm the sole maintainer and the creator of the app.
    I believe 2 people (@weresloth and @Titokhan) work on the cyanogen-ota-bacon site.
    armmani2001 and williamhaven like this.
  13. fdroko
    Jelly Bean Nov 4, 2015
    fdroko , Nov 4, 2015 :
    the application returned to work properly
  14. JorgeA
    Eclair Nov 4, 2015
    JorgeA , Nov 4, 2015 :
    Same here (Australia)
  15. JorgeA
    Eclair Nov 4, 2015
    I got it this morning (AUS time), so just downloaded and installed. Everything seems fine so far, nothing has changed. I expect I may find out more about it as I use the phone but so far so good.
  16. netllocke
    Ice Cream Sandwich Nov 5, 2015
    netllocke , Nov 5, 2015 :
    Try saving data and do a factory reset n update latest patch.
  17. netllocke
    4G or LTE they are both the same, as for about phone it reflect your telco preference of naming its type of data services, nevertheless I preferred 4G cause its 2digits which save valuable space on the notification bar.
  18. netllocke
    Or keep its stock since now the security updates are coming along fast from Google
  19. netllocke
    What the big deal on this anyway?
  20. netllocke
    Very much and very smooth too.
