50
Just recieved YOG4PAS3JL OTA
  1. agustine
    Donut Nov 3, 2015
    agustine , Nov 3, 2015 :
    bro..as i said there is a tool named oneplus one tool box,,dat can help u to do this ucan do every thing..neither root nor twrp is a matter..use it u can feel it
  2. kunjanprasad.12
    Froyo Nov 3, 2015
    kunjanprasad.12 , Nov 3, 2015 :
    1.Boot into twrp.
    2.Clean install YOG4PAS1N0l (just flashing stock recovery won't work).
    3.If stock cyanogen recovery doesn't boot, take the recovery.img file from fastboot zip and flash it via adb (installing recovery via twrp won't work as sometimes twrp modify md5 and binary file needed for verification).
    4. Use stock recovery to install incremental update.
  3. greendragon
    Ice Cream Sandwich Nov 3, 2015
    greendragon , Nov 3, 2015 :
    Just installed the incremental and now trebuchet is crashing every 2 seconds...phone is completely stock and unusable at the moment...any advice?
  4. agustine
    Donut Nov 3, 2015
    bro i u just use oneplus one tool box u can do every thing :)
  5. kumballa
    Cupcake Nov 3, 2015
    kumballa , Nov 3, 2015 :
    THX Cyanogen - Google Play Service still crashing after the update and a much too big google search bar!
    What the f**** is going on???
  6. Spannaa
    KitKat Nov 3, 2015
    Spannaa , Nov 3, 2015 :
    It must be re-setting the tamper flags then - if you want to use a toolbox and not know what's going on behind the scenes then that's up to you - messing with the tamper flags risks bricking your device.
    Not sure why you were advising re-locking anyway - it's completely unnecessary.
    ScorpioPirate likes this.
  7. Limitbreak
    Gingerbread Nov 3, 2015
    Limitbreak , Nov 3, 2015 :
    Does the ota work with encryption? I'm on PAS2QL ATM but can't manually flash the update, says it can't mount data /error :( can't adb sideload either no access to PC :( :( :( :(
  8. Gaurav910
    pacha likes this.
  9. gewoon_emile
    Froyo Nov 3, 2015
    gewoon_emile , Nov 3, 2015 :
    Strange, again an update? The update tracker app that you can download in the playstore doesn't say that there is a new update. Is this an official update?
    armmani2001 likes this.
  10. elya90
    elya90 , Nov 3, 2015 :
    I need a method that doesn't erase me all datas...otherwise, I will do the fastboot install, better than everything else
  11. hogwarts1982
    hogwarts1982 , Nov 3, 2015 :
    Have others got this update too? I am yet to install the update. Will update thread once I do so.
    jagdeepb likes this.
  12. Thingist
    Thingist , Nov 3, 2015 :
    If it is really true that people are getting OTA update notifications and are able to update OTA, the only logical explanation is that the OTA process has been changed in such a way that the update tracker does not work any more. Neither does http://cyanogen-ota-bacon.somee.com/ or https://fota.cyngn.com/api/v1/update/get_latest?model=bacon&type=STABLE, which both result in error. The links provided in this thread are legit enough.
    CasperTFG likes this.
  13. i5xswipe
    i5xswipe , Nov 3, 2015 :
    Thanks, it was edited in on the last post of page 1. Found it now!
  14. hogwarts1982
  15. hippycy
  16. hogwarts1982
    I see, I searched for this topic but didn't find any and so created this thread. Anyway, off I go to install this update.:).
    hippycy likes this.
  17. gmo8492
    Lollipop Nov 3, 2015
    gmo8492 , Nov 3, 2015 :
    Not to me, I only check the forum once a day and its good to see other posts about new updates instead of just one. OnePlus doesn't even announce them anymore.
  18. Morttem
    Morttem , Nov 3, 2015 :
    I did not, hope this will fix my phone call problems, because it really sucks.
  19. millicoelho
    Eclair Nov 3, 2015
    millicoelho , Nov 3, 2015 :
    Yes it(OTA) worked for me
    Limitbreak likes this.
  20. ndy4eva
    Gingerbread Nov 4, 2015
    ndy4eva , Nov 4, 2015 :
    just updated to latest OTA.
    I noticed LTE sign changed to 4G. other than that, i didn't notice any changes. will monitor for battery and other issues.
