Karbon protect case
  1. prompt.ankitg
    Gingerbread Apr 7, 2018
    prompt.ankitg , Apr 7, 2018 :
    I got this one for 5T, wanted to know if this protects the same way as the in-box protection case. I didn't go for bumper case as it weighed more, hope the decision is correct?
  2. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Apr 7, 2018
    NeVeR_SeTTLe , Apr 7, 2018 :
    Don't use the case that was provided in the box as it causes paint chipping. The dirt and grime get under the case and that is what causes the chipping issue. Your better off with the Karbon Bumper case. It can protect your device from minor falls but not major falls.
    Jish98 and Nick 59 like this.
  3. prompt.ankitg
    for accidental damages I have the cover , thanks for your inputs. post the comments on that paint issue I opted for this case, hope it doesn't have the paint related issues atleast
  4. NeVeR_SeTTLe
    The Karbon case doesn't have any paint chipping issues. That is for sure.
  5. prompt.ankitg
    super
  6. Gauravgiri
    Eclair Apr 12, 2018
    Gauravgiri , Apr 12, 2018 :
    i am using carbon from the beginning I bought op5t. it has unnecessary upper cut, I had a dent there. back surface is prone to get worn and texture gets smooth, less able to provide good grip. It does cause PAINT CHIPPING, specially from side. Camera cut out is not even 0.5 mm taller to protect it. also they overcharge for it. I wish you hadn't bought it.
    prompt.ankitg likes this.
  7. prompt.ankitg
    Gingerbread Apr 12, 2018
    prompt.ankitg , Apr 12, 2018 :
    yeah, I am noticing the issue with cuts , paint chipping is something I was expecting that it won't happen. may be I will have to continue rotating cases
  8. Gauravgiri
    Eclair Apr 12, 2018
    Paint may wear off during changing the cases only.. It's not that easy to remove carbon protective case
  9. prompt.ankitg
    oops any suggestions for the case then ?
  10. the98kid
    Ice Cream Sandwich Apr 12, 2018
    the98kid , Apr 12, 2018 :
    i don't know if paint chipping but there are some white dots (patches) all over the back and i can't remove them even with alcohol. using karbon bumper case (official one) with OP5.
    prompt.ankitg and Gauravgiri like this.
  11. the98kid
  12. Praty_28
    Jelly Bean Apr 12, 2018
    Praty_28 , Apr 12, 2018 :
    Don't think too much about it if you bought it use it. If you use your phone with care nothing will happen. Just slap the case on and use it normally dont keep removing it to check about the paint chipping. Remove the case once a month and clean the back panels of your device with a cloth as dust gets accumulated due to the top and bottom open sections of the cover. I have the carbon case on my 3T and its still awesome after 1 year of use, the texture almost cannot be felt now but it still looks great
  13. prompt.ankitg
    thanks mate. will do that. thanks a ton
    Praty_28 likes this.
  14. Gauravgiri
    Eclair Apr 12, 2018
    Skin and case or the softer silicon case would be nice.. Even the default case given with phone is better I guess.
  15. ChuChuu
    Cupcake Apr 16, 2018
  16. mkmanoj1717
    Eclair Apr 16, 2018
    mkmanoj1717 , Apr 16, 2018 :
    If you want to prevent pain chipping, you must remove the case and clean the device at least once in a week.
  17. Ribu singh
    Froyo Apr 16, 2018
    Ribu singh , Apr 16, 2018 :
    it's not carbon fibre it's kevlar. To be precise DuPont kevlar.
  18. varungooner
    Gingerbread Apr 16, 2018
    varungooner , Apr 16, 2018 :
    Hey guys wanted to ask, will you like get the OP5T official cover from the OnePlus authorised store?
  19. Alex_Plaze
  20. prompt.ankitg
    prompt.ankitg , Apr 16, 2018 :
    yes, whats the matter ?
