35
[KERNEL] [blu_spark r107] [OOS 5.* / 8.1 custom ROMs]
  1. ernestolefebre
    Donut Dec 26, 2017
    ernestolefebre , Dec 26, 2017 :
    I have the Magisk 14.6, would it work?
    #41
    eng.stk likes this.
  2. agoinfly
    Marshmallow Dec 26, 2017
    agoinfly , Dec 26, 2017 :
    Yep, it works
    #42
    eng.stk likes this.
  3. ernestolefebre
    Donut Dec 27, 2017
    #43
    agoinfly likes this.
  4. eng.stk
    Froyo Recognized Developer Dec 27, 2017
    eng.stk , Dec 27, 2017 :
    blu_spark r74 unified (oreo)
    All right crew!
    Ho Ho Ho, new Oreo build is up :highfive:
    It's now unified, should be good also for any upcoming 5T Oreo stuff :good:
    Because of latest TWRP and Oreo changes, you'll need to use TWRP 3.2+ or my unified TWRP 3.2.1-x blu_spark v8.61 (recommended).
    Any other versions will not have full support for the kernel and the installer.
    Because of latest Oreo changes, mind that for now on builds will touch system partition.
    So if you want to go back to stock just backup boot and system beforehand or dirty flash you ROM zip.
    Install process is the same as always: ROM+root solution+kernel zip.
    Keep in mind that by default kernel is FBE forced encrypted and supports ext4 only. If you are unencrypted or using anything else than the default, inform yourself beforehand and leave that stuff out of this thread.
    This is for Oreo OOS 5.* only.
    blu_spark_r74-oos-oreo_op5-op5t_102e26b.zip
    Keep it real, keep it true, keep it blu :highfive:
    Merry Christmas and a Happy New Year
    Keep in mind: I will give no active support for custom ROMs (including OOS based ones) or OB.
    Meaning, if using anything besides stock and stable OOS don't bother posting about it.
    I am only interested on debugging stuff in stock and stable OOS (with logs and reproducible steps to replicate the issue).
    Don't spam this thread with CM or other ROMs stuff like "this don't work, my app doesn't open, etc" or debugging features.
    Custom build isn't compatible with EAS stuff.
    Also don't go spam and bug reporting on ROM threads if using this.
    No mirrors please
    If you like my work, donations are always welcome.
    Don't forget to hit thanks and rate the thread nicely, it's free ;)
    #44
  5. eng.stk
    Froyo Recognized Developer Jan 8, 2018
    eng.stk , Jan 8, 2018 :
    blu_spark r77 unified (oreo)
    All right crew!
    Happy New Year peeps, new Oreo build is up :highfive:
    Oreo builds are unified, also good to go on 5T Oreo stuff :good:
    OB3 latest kernel code positively working on OOS 5.0 stable and 5T OB1 (not much changes really). I will try to go like in OP3/3T, as long as OB kernel code doesn't break anything, I'll try to merge it.
    This is for Oreo OOS only.
    blu_spark_r77-oos-oreo_op5-op5t_48439be.zip
    As a sidenote: if you want to test OB and don't want to format your data, you can use stable OOS FW and you're good to go :)
    You can find it here
    Just flash ROM and the FW zip before reboot (I tested with this one).
    Keep in mind: I will give no active support for custom ROMs (including OOS based ones).
    No mirrors please
    #45
  6. Mullafabz
    Gingerbread Jan 9, 2018
    #46
  7. eng.stk
    Froyo Recognized Developer Jan 12, 2018
    eng.stk , Jan 12, 2018 :
    blu_spark r84 unified oreo
    All right crew!
    New Oreo build is up :highfive:
    Any other versions may not have full support for the kernel and the installer.
    blu_spark_r84-oos-oreo_op5-op5t_50049b9.zip
    No mirrors please
    #47
  8. eng.stk
    Froyo Recognized Developer Jan 17, 2018
    eng.stk , Jan 17, 2018 :
    blu_spark r90 unified (oreo)
    All right crew!
    Also mind that for now on builds will touch system partition (Oreo stuff).
    Code is tested for OB4/OB2, but also worked on 5.0.1 and OB1.
    blu_spark_r90-oos-oreo_op5-op5t_4b7f25d.zip
    No mirrors please
    #48
  9. agoinfly
    Marshmallow Jan 18, 2018
    agoinfly , Jan 18, 2018 :
    Thank you for the update!
    #49
    eng.stk likes this.
  10. eng.stk
    Froyo Recognized Developer Jan 18, 2018
    #50
  11. eng.stk
    Froyo Recognized Developer Jan 22, 2018
    eng.stk , Jan 22, 2018 :
    blu_spark r90 unified (oreo custom)
    All right crew!
    New custom Oreo build is up :highfive:
    Because of latest TWRP and Oreo changes, you'll need to use TWRP 3.2+ or my unified TWRP 3.2.1-x blu_spark v8.68 (recommended).
    Build was tested in LOS 15.1 ad OMNI 8.1 (big shouts to LOS guys and specially OMNI darkobas for the nice work on 5/5T trees, senior members do it better :) )
    This is for Oreo 8.1 custom ROMs only.
    blu_spark_r90-custom_oreo_op5-op5t_73d693d.zip
    No mirrors please
    #51
  12. eng.stk
    blu_spark extras v8.68
    All right crew!
    Here's an updated TWRP with all the blu_spark goodies inside and fully synced with TWRP Android-8.1 branch (including more recent upstream than official TWRP) and some specific device fixes.
    Fully synced with TWRP 3.2.1+, name changing to reflect base 8.version, full compatible with OOS Oreo 8.1/8.0 stuff and Nougat.
    TWRP blu_spark edition is not only universal but also unified, works for both OP5/5T. And it's even faster than v8.61 :)
    Big shouts for codeworkx 8.1 crypto patches work and also nkk71 (RIP) for the awesome work on omni minimal trees :highfive:
    twrp-3.2.1-x_blu_spark_v8.68-op5_op5t.img
    Wakelock blocker info and example script
    Android wireguard-tools Magisk Module
    I'm just sharing my personal mods since people asked, meaning no support will be given (don't bother post about it).
    If your cat get's on fire you're on your own ;p
    No mirrors please
    #52
  13. eng.stk
    Froyo Recognized Developer Jan 29, 2018
    eng.stk , Jan 29, 2018 :
    blu_spark extras v8.69
    All right crew!
    Delete your twrp folder before changing between versions (copy your backups to somewhere else before) or else issues may arise.
    twrp-3.2.1-x_blu_spark_v8.69-op5_op5t.img
    No mirrors please
    #53
  14. eng.stk
    blu_spark r93 unified (oreo)
    All right crew!
    Because of latest TWRP and Oreo changes, you'll need to use TWRP 3.2+ or my unified TWRP 3.2.1-x blu_spark v8.69 (recommended).
    This is for Oreo only.
    blu_spark_r93-oos-oreo_op5-op5t_32e56f9.zip
    blu_spark_r93-custom_oreo_op5-op5t_f9f00fe.zip
    No mirrors please
    #54
    agoinfly and Mrfloflo like this.
  15. agoinfly
    Marshmallow Feb 6, 2018
    #55
    eng.stk likes this.
  16. eng.stk
    Froyo Recognized Developer Feb 7, 2018
    eng.stk , Feb 7, 2018 :
    blu_spark r96 unified (oreo)
    All right crew!
    If coming form other kernel always dirty flash your ROM (and root if that's the case) beforehand.
    blu_spark_r96-oos-oreo_op5-op5t_8ebf15e.zip
    blu_spark_r96-custom_oreo_op5-op5t_514960b.zip
    No mirrors please
    #56
  17. eng.stk
    Froyo Recognized Developer Feb 10, 2018
    eng.stk , Feb 10, 2018 :
    blu_spark r99 unified (oreo)
    All right crew!
    blu_spark_r99-oos-oreo_op5-op5t_11c5bb7.zip
    blu_spark_r99-custom_oreo_op5-op5t_3f83ac5.zip
    No mirrors please
    #57
  18. cirillo30
    Gingerbread Feb 11, 2018
    #58
  19. eng.stk
    Froyo Recognized Developer Feb 12, 2018
    eng.stk , Feb 12, 2018 :
    Great for most people. But if you already have bad battery life, don't expect kernel to turn it great miraculously.
    #59
    cirillo30 likes this.
  20. eng.stk
    Froyo Recognized Developer Feb 27, 2018
    eng.stk , Feb 27, 2018 :
    blu_spark r102 unified (oreo)
    All right crew!
    So, if you want to go back to stock, just backup boot and system beforehand or dirty flash you ROM zip.
    If coming from other kernel always dirty flash your ROM (and root if that's the case) beforehand.
    blu_spark_r102-oos-oreo_op5-op5t_ba379f5.zip
    blu_spark_r102-custom_oreo_op5-op5t_6e0f23c.zip
    No mirrors please
    #60
