49
ROM kingmercians Hydrogen OS | H2OS 1.2 | 6.0.1 | CLEAN | GAPPS | DEBLOATED
  1. vishnu89
    Donut Feb 28, 2016
    vishnu89 , Feb 28, 2016 :
    It's lollipop
    GhostSamuraiX likes this.
  2. MasL
    Donut Feb 28, 2016
    MasL , Feb 28, 2016 :
    I've seen many issues with custom ROM for the OnePlus Two, I was just wondering if this custom ROM has any problems with fingerprint scanners or anything else apart from the bugs listed?
    Cheers!
  3. blureshadow
    Froyo Feb 28, 2016
    blureshadow , Feb 28, 2016 :
    there are almost no problems with the fingerprint scanner. However there're large battery problems while the screen is active. For example, I have followed v7's guide for battery "fix" and I had 0% battery drain per hour for 6 hours xD but as soon as I turned the screen on and opened a few apps, in 15 minutes it dropped by 4%.
  4. Spannaa
    KitKat Feb 28, 2016
    Spannaa , Feb 28, 2016 :
    Use Advanced Power Menu instead - it's integrated with the power button like a 'real' advanced reboot would be.
    blureshadow likes this.
  5. rur0un1k3nsh1n
    Froyo Feb 28, 2016
    rur0un1k3nsh1n , Feb 28, 2016 :
    Sorry, but do you need root for viper4android or do you just need to flash it in twrp?
    Also, what exactly does viper4android do to make audio better? Does it make it better for internal speaker, or headphones or both?
  6. blureshadow
    Froyo Feb 28, 2016
    Viper is a system equalizer. I don't know if you need root for it, but since this rom is prerooted, it will work (I'm using it) and it works for speaker, headphones, docks and others.
  7. saanty
    Eclair Feb 28, 2016
    saanty , Feb 28, 2016 :
    downloading failed 3 times on mega drive.:(:(:(... someone please give me the latest rom zip file link on another drive like google, mefdiafire etc etc..
  8. Mr.fr34ky
    Eclair Feb 28, 2016
    Mr.fr34ky , Feb 28, 2016 :
    Does anyone have a decent guide how to switch 4g off when screen is off with tasker/secure settings plugin?
    Thank you!
  9. Eshan_Anand
    Ice Cream Sandwich Feb 28, 2016
    Eshan_Anand , Feb 28, 2016 :
    gravity box has an option to switch network when screen is off.
  10. Mr.fr34ky
    Eclair Feb 28, 2016
    Great I was playing around with gravity box when the system ui is crashed and left we with no option just to restore a nandroid backup.. forducksake
  11. fxguru77
    Jelly Bean Feb 28, 2016
    GhostSamuraiX, josefn24 and dinjesk like this.
  12. blureshadow
    Froyo Feb 28, 2016
    I too have problems with screen using a lot of battery. do you have gestures disabled? that might help a bit with it turned off. (I haven't found a fix yet for the battery drops in active use)
  13. dinjesk
    KitKat Feb 28, 2016
    dinjesk , Feb 28, 2016 :
    I have a wifi bug.
    Wifi keeps eating my battery while everything that has something to do with wifi is turned off.
    Any fix?????
  14. blureshadow
    Froyo Feb 28, 2016
    Do you have wi-fi scanning disabled? There's an xposed plugin to activate the wi-fi scanning and bluetooth scanning settings that should normally be under Location, but in About > License Information. Check that out and see if you have them disabled.
  15. dinjesk
    KitKat Feb 28, 2016
    All wifi settings are off.
    Can you tell me what module to download?
  16. blureshadow
    Froyo Feb 28, 2016
    "OP2LocationScanningEnabler"
    bestlands and dinjesk like this.
  17. dinjesk
    KitKat Feb 28, 2016
  18. basshunter
    Cupcake Feb 28, 2016
    basshunter , Feb 28, 2016 :
    Help guys... before installing this rom the adb was working correctly.. eg. the phone was listed on the adb devices..
    Right after the h2o flash, my pc detects the adb device, driver is installed and everything is like before, but adb can't really detect the phone. I installed every kind of adb driver possible, reinstalled adb, wiped the phone, gave permission to my pc from the popup and so on... fastboot detects the phone instead.. I can use adb over wifi tho.
    Please help me or i'll have to roll back!
  19. ULTIMATE2015
    Gingerbread Feb 28, 2016
  20. Wahoux
    Lollipop Feb 29, 2016
    Wahoux , Feb 29, 2016 :
    Hello
    Big issue
    when I turn off and turn on my OP2, no battery drain
    But if i shedule the automatic turn off for the morning for example, i have a huge battery drain, 10-15% in 10-15min without use my phone!
